Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 2007 Bambi all models
Old 09-14-2007, 12:31 AM   #1
tetstream
tetstream's Avatar
Profile:  2007 19' Bambi
Somewhere , Between the Tetons and the SF Bay
short tongue -- Why?
Hey All -
Picked up my new 2007 75th Ann SE a few days ago. The tongue of the trailer is so short that my tailgate won't drop down on my truck because it hits the jack. I looked into a ball mount extension...which will work... but the load capacity is reduced at least by 1/3 with those things. I don't like reducing such things and adding another point of failure. My guess is that it'll make noise too.
Why would Airstream design such a thing? Seems dumb to me...because...who doesn't need to get into the back of their rig while towing ??
tetstream is offline   Reply With Quote
Old 09-14-2007, 01:28 AM   #2
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
FYI - I can't fully open my tailgate either and I have a 1965 Airstream. I also had a 1965 Aristocrat and couldn't open my tailgate with it either. Don't know why but it is pretty common.
Solution - Load truck first then hitch trailer
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 09-14-2007, 01:29 AM   #3
CaddyGrn
Profile:  1963 16' Bambi
Yreka , California
WE have a 1963 Bambi and the same rule applies... so we reach over the back of the truck or unhitch!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 09-14-2007, 05:35 AM   #4
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
Some hitch bars come with two holes and therefore you can choose of which one to use. That is what I have done. I do like the close hitch configuration. If you have a heavy longer trailer and potential sway problems there is a trade off if you want to move the hitch point back. Distance from the ball to the jack seem to be the same on my '63 and my '77 so it seems Airstream has standardized on that dimension. Suburbans with rear doors do not have the problem and there were alot more Suburbans used in the old days rather than trucks with tailgates.
Old 09-14-2007, 05:41 AM   #5
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
My tailgate opens. I've got a Reese Dual Cam HP hitch bar. What's yours? This hitch bar has two holes for the hitch pin -- I use the closest, tightest one too. Hitch specs say it's plenty strong even on the further out one. But you are right to worry about those darn Chev receivers:
Chevy Factory Hitch Problems
Check your Chevy Factory Hitch
http://www.airforums.com/forums/f464...les-34603.html
Old 09-14-2007, 05:41 AM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by tetstream
Hey All -
Airstream didn't design the basic A-frame, physics did.
It's a great example of a "moment arm."
Because it's subject to the shock from the tow vehicle and roads, it moves vertically.
The longer it is, the more it would move. The more it moves, the more risk it has of breaking at the shell.
As it is, some owners manage to break them at the shell.
Therefore they must, be as short as possible.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 09-14-2007, 06:25 AM   #7
overlander63
Rivet Masher
overlander63's Avatar
Profile:  L.A., Dammit , California
There is a solution, albeit rather redneckian (is that a word?) Go to your favorite truck parts shop, and get a tailgate for use with a gooseneck trailer or fifth wheel. The V area in the center of the tailgate will allow the gate to drop down on either side of the jack. This would work best on a pickup with no cap (topper), as the gap would loook decidedly strange if it had a cap.
Old 09-14-2007, 08:23 AM   #8
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Another option is to move the jack rearward a few inches. Thats what I did on a flatbed trailer of mine.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 09-14-2007, 08:29 AM   #9
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
All this time I thought this was normal. If I use my load distribution hitch, I can lower the tailgate. If I use just a simple ball hitch, the 4" that it's shorter allows the tailgate to hit the jack. To my simple mind it was nature's way of saying "use a load distribution hitch, newbie!"
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 09-14-2007, 09:08 AM   #10
tetstream
tetstream's Avatar
I certainly understand this reasoning, and figured (Hoped) there was a real engineering reason, however, for the mucho $$$$ that Airstreams command, one would think that the engineers would beef-up the A-frame/shell assemblies to account for this functionality flaw. I mean, after all, these are recreational vehicles. You're gunna be getting in and out of the TV...a little or alot... and in an emergency too for gear, etc.
Would you use a ball mount extension ???
Old 09-14-2007, 09:28 AM   #11
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
I do not have that problem with my 250. I can drop the tail gate while hitched with the reese dual cam. Maybe you need a bigger truck ;-)
Any manufacturer that is in it for the money will make anything as small or light as possible to save money.
I just looked at your picture. I have way more room than that. I can go almost 90 degrees truck and trailer and not hit anything. It has and I was not in control. see my website.
Michelle
Think you are having a bad day? Go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 09-14-2007, 09:53 AM   #12
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Isn't it possible that different truck models have different height tailgates - thus length when open? I would also imagine the model of hitch being used plays a role in determining the maximum distance present.
How can Airstream design for every possible truck/hitch configuration? Especially if physics say a shorter tongue is better...safety first!
From your photo...it appears the tanks/cover are pushed forward quite a bit which in turn move the jack forward. Is the space between the tanks & trailer for a spare tire (like on my '64) or ??? Could you move the tanks & jack back any? Or move the tanks back and turn the head of the jack around to face the other way.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 09-14-2007, 09:59 AM   #13
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
The distance from the bumper of the TV to the ball will make the greatest amount of difference. My Reese puts the ball over a foot away. No problem with the tailgate.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 09-14-2007, 10:39 AM   #14
CanoeStream
Images: 13
No Antisway in picture?
The significant thing about your picture -- do you have a bare hitch bar on the truck? With a ready-to-camp hitch weight of maybe 600# you wouldn't be overloading your rear axle. But going without antisway could really be a problem. It is said that anesthesiology is 99% boredom and 1% sheer panic. You enter that domain without the antisway. I have had my antisway save me only once (exactly 1 year ago) but it was well worth it!
There's no way to get around the weight distribution aspect of antisway (eg, Equal-I-Zer or Reese). But it will give you a bit longer hitch bar and might address your tailgate issue at the same time.
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 05:34 PM
Tracing a short LI Pets Lights - Interior & Exterior 10 04-30-2007 11:59 AM
I'm a little short, can u help? Shorty Electrical - Systems, Generators, Batteries & Solar 1 05-28-2006 01:46 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 02:41 PM
12 v short Don McKelvay Electrical - Systems, Generators, Batteries & Solar 8 10-26-2003 12:44 AM
