I have recently purchased a new 2008 19' Bambi SE and On my past several camping trips I have emptied my water tank before travel. When I get to the State park and hook up to the water supply I find that my water tank is full and needs to be drained before the trip home. I thought the tank and the city water supply where seperate. ps There is no 2008 Bambi Thread.
You are correct...when you are hooked up to city water with an empty fresh water tank, the fresh water tank should not fill up internally from the city water....that is, unless it's been re-plumbed with a water pump bypass to allow filling from the city water connection ( in which case there would be valves to open and close routing the water around the pump)...and if it's new, that's doubtful. It sounds like your water pump (which you do not need to use when you are connected to city water) may be allowing water to back-flow into the fresh water holding tank when it's under city water pressure. It should not be allowing water to flow that direction. If the tank is getting filled to the point that it's completely full, you will have water overflowing on the outside through the overfill tube/hole next to the fresh water fill port....and you did not mention that happening, so it may be a small "seeping" into the fresh water tank. Check in the dinette street side seat where the pump is, to see if anything looks like it is not behaving correctly... and have it checked out...it's still under warranty.
__________________ TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI Four Corners Unit #3954 Décor Site: AZBambi Décors
Do you hear the water pump kick on when you run the water? If so, maybe the two hose connections are mislabeled. You could be filling the tank unintentionally.
__________________ I know the voices in my head aren't real, but some of them have pretty good ideas.
AIR 22749 1974 25' Tradewind - no TV yet 1989 345 LE Classic Motorhome Courtesy Parking; 20 amp, water, dump, wifi 'tween exits 27 & 33, I-75
I just read the manual and it does state that the water pump has a check valve to prevent city water from entering the water tank. I must have a faulty pump. I have inspected the pump and tank and there is no leaking, the tank will fill up but has not overfilled to the outside. I am taking the unit in for some other warranty work ( refer door has a torn seal found on inspection, they have ordered a new door.)
