Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi > 2007 Bambi all models
Old 09-02-2008, 10:19 AM   #15
DandB^2's Avatar
Profile:  2007 16' Bambi
Reno , Nevada
Originally Posted by Silvertwinkie View Post
On other fronts:
Doug, welding a hitch to the frame is NOT best practices. We had a long, long discussion on this subject a month or so ago and I finally called the factory. The tech on the phone clearly and very directly stated
"The unit is not designed for this additional weight" "Anyone adding weight to the rear exterior of and Airstream, will eventually see frame separation from the body...it's not a matter of if, it is a matter of when" "anyone doing this is just asking for problems" Again, all these statements were from Airstream tech support on a live phone call.
THanks for the heads up on this. I guess I should have checked into this before welding that on.
DandB^2 is offline   Reply With Quote
Old 09-02-2008, 12:39 PM   #16
2airishuman's Avatar
Profile:
Originally Posted by Road Ruler View Post
... YOU GOTS TO DRIVE IT TO UNDERSTAND.
wacky is as wacky does.
drivers wanted...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Finally Pulled the Trigger Blevi Member Introductions 4 02-10-2008 03:41 PM
Toyota RAV 4-V6 pull 16-ft Bambi? Skye Nomad Tow Vehicles 11 12-31-2007 07:47 AM
A Few Questions - Winterizing an 07 Bambi campadk Winterizing, Storage, Carports & Covers 20 11-09-2007 05:01 PM
Questions on ordering a Bambi BobSenigo 2007 Bambi all models 4 10-10-2007 11:09 AM
19' Bambi questions... yosemitesam Towing, Tow Vehicles & Hitches 33 03-04-2005 06:46 AM
