Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 10-21-2019, 12:56 PM   #1
Wabbiteer's Avatar
Jupiter , Florida
Talk me down from tire/wheel purchase - or where is the deals on 16" rims?
Wheel capacity: 2,540 lbs, I'm in serious like with the wheel.
I've got a '73 27' perpetual rehab project and I want wheels and tires to shuttle the empty shell around, might be moving soon too - trailer dry weight was 4750 and listed at 6300 GVWR -
This will be a lightweight aluminum tent if used as an RV, and work as a mouseproof drygoods storage shed for the foreseeable future.
I do NOT plan on replacing all the built-ins. There will be greywater tank only, and a 15-25 gallon freshwater tank.
This $170 X 4 combination is maxing out my budget already, wondering if MN tax will be collected too
https://www.etrailer.com/Tires-and-W...25RLW6FPB.html
Otherwise - anyone know any better deals out on the interwebby?
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 10-21-2019, 03:28 PM   #2
Wabbiteer's Avatar
Jupiter , Florida
Oh - here is a photo... $680ish, haven't committed to see tax.
Old 10-21-2019, 06:32 PM   #3
Flht2k's Avatar
sacramento , California
Easy. I have nokians for my 15 in rims. Best tire out there an lt tire. Check them out. About 450 installed. Check simply tire
Flht2k is offline   Reply With Quote
Old 10-21-2019, 07:16 PM   #4
Wabbiteer's Avatar
Jupiter , Florida
With steel rims 46~ years old they've shown me it is time to replace them.
Long term parking means moisture collects on the downhill round rubber crevices and gets pretty deep down the side rings above the tires bead seat - freeze/thaw must really amplify this, be able to see a crescent fissure running for 5, 7, 10 inches as wide as they are deep - 1/8" is probable now or better.
I bead blasted and painted these wheels 6 or 8 years ago, was time then and surely really time to swap them out now.
Remember jumping from a D to E can cause mysterious rim failures with these old wheels, the above may be a very good clue to that.
15" nokians on 15 in rims... I'm with that, sure...
...but am secretly hoping someone flags a good deal away from 15" to bump up to 16" blah blah
Old 10-22-2019, 10:24 AM   #5
2020 23' Flying Cloud
Albuquerque , New Mexico
I have 4 used Sendel wheels 16 inch that I am looking to part with. I don't know about the shipping cost from NM where I live to Minnesota but perhaps we can work it out. If youre interested give me a shout.
Nightowl is offline   Reply With Quote
Old 10-22-2019, 10:58 AM   #6
Wabbiteer's Avatar
Jupiter , Florida
Nightowl?
Gracious offer, you need to put those on classified and have someone local pick them up - making a solid contact locally in the AirForums community IS worth it, I'd just be a one-and-done deal
- I hate the idea of causing someone the hassle of finding boxes and doing the UPSy dance. IF* I were about 1700 miles closer you'd be seeing me tomorrow!
Old 10-22-2019, 11:59 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Sounds like you have your mind made up.
Why don't you pull the trigger?
>>>>>>>>>Action
Old 10-22-2019, 05:49 PM   #8
CruizinDux's Avatar
Washington , Missouri
There are a number of threads on the gym's 15>16 that went pretty much silent when the GYE's were introduced. Google ray ecklands..michlen 15 to 16 (or=). Everybody was buying the new rims and mich tires.
I had zeroed in on the 15 nokians...why but new rims...i see a lot of them around Eugene, mainly on trucks and a lot on horse trailers.
I was ready to order them and the gye's came out. Uhhh...still a goodyear like the gyms. Then just befire departure to Nashville...uhhh...slightly larger profile. Fits in wheel well but may not in spare bracket...a little wider.I
So sent fir the gye's and lovd them. Basically same rating...lots of good threads re pressure and speed ratings. Currently on 3rd cross country trip and pushing 35k miles on the gye's.
To be clear, i suspect the nokians are therir equal...gye's a little cheaper and certainly more a available. Noks are now made in TN, so that probably has changed.
Lots of threads on the gye's. When i'm on another device I'd be glad to look in my tjre folder and post.
B
The one part that tireman9 and others have mentioned is that the gye's have a thinner (weinie tire was my term) but that apparently translates to a cooler running tire. That seems true plus they hold pressure like no other.
CruizinDux is offline   Reply With Quote
Talk about DUMB! Allowed HVAC coil cleaner to run down side of newly polished A.S.! griffithj Cleaning, Stripping & Polishing 17 05-23-2019 05:57 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Talk me down! Foiled Again Off Topic Forum 20 05-19-2008 06:30 PM
Someone please talk me down-- i don't want an SOB! bakerliz Off Topic Forum 19 04-01-2008 07:06 PM
