Old 05-26-2005, 03:47 PM   #1
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Yikes! What is it?
The previous owner of my motorhome (Chummy) put decals on the front side panels, under the driver's and passenger's windows. They were removed when I purchased Chummy so I never got to see the decals and can only guess as to what they looked like. Now I have the results. Several "experts" had assured me that once the clear coat was removed the finish would be the same. Theory being that the decals removed the clear coat. OK I bought it and removed the clear coat and the marks are still there.
I have attached pictures. This motorhome was built in mid-1982 and most likely has a mixtures of aluminum on it so I do not want to polish the entire unit. I will be giving the entire unit a very good detailing and shining. As I have stated the clear coat has been removed from the entire front panels. What I wonder is if I start with a metal polish can I expect to remove those marks or only make them worse?
Name:	Chummy spot 003.jpg
ID:	12441   Click image for larger version
Name:	Chummy spot 007.jpg
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 05-26-2005, 03:51 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Now you've done it! I see a polished MH in your future
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 05-26-2005, 04:06 PM   #3
Rivetedude's Avatar
Yorktown , Virginia
Send a message via Yahoo to Rivetedude
Yessiree...The decal area has been exposed to the weather all those years when the rest of the coach under the clearcoat has not. I'm not sure how you can make it look the same without doing the whole coach. I'm sure there's enough expertise here though. Somebody will be able to tell you.
Ben
Rivetedude is offline   Reply With Quote
Old 05-26-2005, 04:59 PM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
If you try any metal polish, you will end up with a very shinny spot instead of a very dull spot.
Both will stand out.
My suggestion... Wait for the promissed "offical" forum sticker and put it over the trouble area!
-Tim
theVAP - Airstream Podcast
Old 05-26-2005, 05:30 PM   #5
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I can see a set of P-40 Warhawk decals in your future! See Steven Webster's avatar for how they'll look on your MH!
Roger
Old 05-27-2005, 07:58 AM   #6
1994 30' Excella
I am a lifelong pacifist so no warhawks on my Chummmy, possibly a large daisy or the 60's peace symbol. Seriously I once had a VW camper and do not want to return to those days. Gratefully the Dead are dead. I would not mind if that entire panel was shiney. I do know that the coach was constructed of different aluminum and the whole body will not shine. AS switched over to a different aluminum in 82. Mine must of been in the middle of the switch. The difference is very evident under the clear coat so I want to be careful not to emphasis that; however these front panels won't matter. Will they buff out?
Chaplain Kent
Old 06-05-2005, 01:41 PM   #7
1994 30' Excella
I have completed the project today and will post pictures of this beauty under the Classic Motor Home forum.
Chaplain Kent
Yikes! Trailer jumped the hitch! 64GT Hitches, Couplers & Balls 33 06-28-2006 01:47 PM
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
SMOKE! Yikes!! Help! SilverToy Interior Restoration Forum 26 04-01-2005 09:50 AM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
