Old 08-24-2016, 01:35 PM   #1
John Rousch's Avatar
1969 27' Overlander
Sebring , Florida
Wing window replacement
While traveling along the interstate, a rock or something kicked up and blew out my road side wing window on my 1969 airstream.
It appears to a complicated replacement.
Anyone done this before and what do I need to do?
Thanks in advance.
John
John Rousch is offline   Reply With Quote
Old 08-24-2016, 03:55 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There are several threads describing this process. Do a google search from outside the forums for "wing window rebuild airforums" and you should get a few threads.
Since you have a 69, with the rare windows, the simplest thing you can do is order a new window assembly (frame and all, you can't buy just the glass), drill out the bucked rivets holding the window frame in place, remove it, goop everything up with lots of vulkem, and then install the new window using Olympic rivets.
When you order your replacement window, you might also get a rock guard assembly to protect your front windows in the future. You might be able to combine the shipping on all of this (as the shipping for the rock guard is high due to its size). Outofdoorsmart.com was recently offering a sale price on their rock guards.
good luck!
Wing Window replacement Zeppelinium Windows & Screens 18 06-20-2018 10:50 AM
1973 Tradewind Wing Window Replacement Question Leadvox Windows & Screens 13 09-14-2016 11:28 AM
wing window replacement tommybb Windows & Screens 0 12-14-2011 12:29 PM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
