Old 05-27-2015, 09:17 PM   #1
1972 27' Overlander
Woodburn , Oregon
White roof coating ?
I'm renovating a 1972 overlander , it has some sort of white roof coating my problem is one of the PO put it on too far down the side and it shows way to much and some spots are starting to flake off
How do I remove this stuff ? And what product do I use to recoat it ? Does someone here have a favorite product they have used with success in the past ? I need some help here !
shineybullet is offline   Reply With Quote
Old 05-27-2015, 09:54 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy.. do you have pics? removing.. well, try some 'Citri Strip'... a little higher on the top so you can test..
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-06-2015, 02:17 PM   #3
1973 29' Ambassador
Def , Michigan
Sounds like you have some elastomeric paint. Good stuff to reduce summer temps and seal the roof.
Coston
1973 Airstream Ambassador
csmauley is offline   Reply With Quote
Old 06-06-2015, 03:36 PM   #4
1972 27' Overlander
Woodburn , Oregon
Thanks guys , I thought I would get more replies though
Old 06-06-2015, 04:35 PM   #5
Central , Mississippi
Here is what I would you do...
Get a couple of small bottles of various strippers. Get in the top center of the roof and try a few spots ti see what works. If it doesn't work, the mess will be hidden.
There are so many different types of coatings its tough to give a one-stop answer.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-06-2015, 04:58 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine leaves white strips down my trailer every time it rains. They wipe off easily but a bit annoying. So watching this for suggestions.
MICHAEL
Old 06-06-2015, 05:06 PM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Is yours the factory coating? It's something I want to do, but don't want any more chalking than "necessary".
I've read that some wax white roof coatings. But no info as to what brand, etc.
Old 06-07-2015, 06:17 AM   #8
AWCHIEF's Avatar
Images: 33
I believe it is. Have also read about the wax trick.
MICHAEL
Old 06-07-2015, 06:44 AM   #9
1998 30' Excella 1000
Livingston , Texas
I have been using automotive wax on my factory/white roof every 6-8 months for 18 years. Early on, I always wondered if it was worth the effort. But it looks great, and no white streaks.
Siegmann is offline   Reply With Quote
Old 06-07-2015, 08:13 AM   #10
1972 27' Overlander
Woodburn , Oregon
Mine is just flaking off in spots from age , it needs to come off and then Re coated with a newer product , this is something a PO has put on and I have no idea what product a person should use to recoat it with ? Any ideas ? Is this something I can buy at Home Depot or Lowes ?
Old 06-07-2015, 09:27 AM   #11
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Here on the forum I've seen mention of a white coating used on school busses. Perhaps, if yo can locate a school bus yard in your area they could point you in a direction to consider. Another suggestion would be to check with Airstream and see what their factory coating is. So far mine is in good condition and not chalking so it's something that I'm not in the market for. YET
Good luck,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-07-2015, 09:30 AM   #12
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
AWC.....I had the same problem with my 2007 25' until I started waxing the roof with Wabernize One Step RV Super Seal twice a year. No more white streaks coming down the roof where the water runs off. Just make sure you let anyone working on the roof of your trailer know that you waxed the roof and it may be slippery.
AEC
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 06-07-2015, 09:32 AM   #13
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
What is the roof coating and how old? On my Ceramiflex chalking stopped after a few years.
Lumatic is online now   Reply With Quote
Old 06-07-2015, 10:54 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ceramiflex no longer sells their product for use on metal roofs. I have begged, pleaded with the manufacturer... no interest.
So, my next choice is to find a high quality AVIATION paint....at least to see if they will sell to me... and price...
Channing
WBCCI# 30676
White roof coating maintenance ???? polarlyse Roof 11 03-31-2015 09:00 PM
Do you have rubber coating on the roof? dbtolman Roof 22 03-16-2009 04:29 PM
removing roof coating airtim Cleaning, Stripping & Polishing 2 04-02-2005 09:43 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
Roof coating FrankR Roof 4 07-22-2002 01:56 PM
