Old 11-14-2009, 06:55 AM   #1
1999 25' Safari
WINDSOR , ON
White residue
i have a 1999 safari with the painted top, it appears that there is a white residue from that leaking down the sides of the trailer at the front and back. has anyone else run into this problem and is there a solution?
garryg is offline   Reply With Quote
Old 11-14-2009, 07:15 AM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Hi Garry,
I have noticed the same thing on our 2005 classic - bought used last Fall.
All I have done so far is to try removing in with Walbernize, a combined cleaner/sealant recommended for Arstreams.
It helps, but doesn't remove all traces. I am nervous to try anything more aggressive in case I cut thru the clearcoat.
I believe you are right in that it is coming from the white paint, that was what I concluded also.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-14-2009, 07:56 AM   #3
1999 25' Safari
WINDSOR , ON
i have no trouble removing it but i would like to stop it from happening.
Old 11-14-2009, 08:41 AM   #4
kstampa's Avatar
2004 28' International CCD
tampa , Florida
Images: 35
yeah i have no trouble removing it either but it is annoying. probably nothing will work short of repainting the top.
kstampa is offline   Reply With Quote
Old 11-14-2009, 08:41 AM   #5
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Just a guess, but the white paint may be oxidizing. A good polish and wax of the roof would help if that's the case.
Good luck,
Ken
Old 11-14-2009, 09:47 AM   #6
lacosta31's Avatar
2007 19' Bambi
2003 22' International CCD
Carlsbad , California
Hi Garry - I noticed the same thing on the 02 we just picked up and yes it appears to be the white paint on the roof oxidizing. I took a step ladder and washed down the white roof (the wash water came out like milk) and took off most the chalky surface. Eventually I will wax it but this helped. I used Meguiar's Scratch Out polish (safe for clear coats) to get the stains off the sides.
Take care.
lacosta31 is offline   Reply With Quote
Old 11-14-2009, 10:00 AM   #7
tpi
Trabuco Canyon , California
I see a little bit of that on mine-it wipes right off.
I'm certain it is the top paint with an oxidized layer. I scrub mine during wash jobs which washes away most of this oxidation. If you're enthusiastic, I have found the white top paint can be polished into a nice shine. That should cut out the white streaks.
tpi is offline   Reply With Quote
Old 11-14-2009, 10:07 AM   #8
_
most solutions WILL BE temporary.
imagine an older car (prior to clearcoating) with paint that is gradually oxidizing away.
THAT is what we have to deal with here.
so wash it occasionally, remove the residue and wax/seal the top panel.
then REPEAT this process 1-2 time per year,
LESS if stored under cover.
TO PREVENT the oxidation of the alcoa TOP paint, one would need to COVER it with something...
CLEARCOAT for example, more paint or one of the better ROOF coatings...
http://www.airforums.com/forums/f478...ite-26756.html
http://www.airforums.com/forums/f474...eam-20970.html
http://www.airforums.com/forums/f456...eam-30305.html
and while U R UP there inspect and tend to the sealants used for the many HOLES...
cheers
2air'
Tape Residue on Clear Coat bennyjackmcr Clearcoat, Exterior Paint & Trim 5 06-07-2009 02:29 PM
Removing Vinyl and glue residue Leya Costa Upholstery, Blinds, Walls & Interior Finishes 2 05-16-2008 08:26 AM
Removing Duct Tape Residue Lumatic Cleaning, Stripping & Polishing 24 01-11-2008 04:03 AM
skin oxidation and red letter residue remover/ it works Lumatic Cleaning, Stripping & Polishing 0 09-08-2007 05:43 PM
Why the battery residue? Kistler Batteries, Univolts, Converters & Inverters 3 11-15-2004 05:39 PM
