Old 07-24-2016, 12:37 PM   #1
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
What's this switch
Right by the rear of the hitch is this switch. What's it for?
Picinisco is offline   Reply With Quote
Old 07-24-2016, 05:34 PM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Doesn't look factor. The light next to it looks like the reverse polarity light. I first thought the switch might turn off the light if you plug into an outlet that is reversed polarity so you don't have to have the light on but then why would you keep it plugged in if it was reversed.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 07-24-2016, 07:20 PM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
If it were mine, I'd see if I could tell where the wires are going.
Ken
Old 07-24-2016, 08:28 PM   #4
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Without an exact evaluation of where the wires are going, it would seem that they cross through floor inside the trailer and disappear under the fridge.
Cheers....John
1977 24ft Argosy - sold.
Old 08-03-2016, 08:59 AM   #5
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
Maybe an obvious question... but what happens when you flip it?
Ryan Jilek
WBCCI 7165 | TAC ND-3
Ms. Streamy - 1971 Overlander Restoration Blog
chilipepper is offline   Reply With Quote
Old 08-04-2016, 08:40 AM   #6
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
I am a long way from doing that at the moment.
Cheers....John
Old 08-24-2016, 10:16 PM   #7
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Mystery solved. The wires run to the IGN terminal behind the fridge which when tripped takes the 12v option away from the fridge. However not sure why it was located where it is.
Cheers....John
Old 08-26-2016, 08:40 AM   #8
1971 27' Overlander
I'm glad you have it solved. Does the fridge in there run on 12v? Maybe they wanted to make sure that they could shut that option off so it wouldn't drain their tow vehicle battery if they parked somewhere for an extended bit of time. Just a thought...
Ryan Jilek
Old 08-26-2016, 12:47 PM   #9
Tincandad's Avatar
1961 24' Tradewind
Exeter , New Hampshire
Complying to Usage in Tunnels or Refueling?
Maybe the PO installed it to turn off the fridge after closing off the propane so they could travel through tunnels or when refueling their tow vehicle?
Tincandad is offline   Reply With Quote
Old 08-26-2016, 10:29 PM   #10
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
From what I have read, the fridge operating priority is 120v, 12v then lp gas. So when towing 12v would be the priority. I can only believe that the po wanted to have this choice as chilipepper suggested.
Cheers....John
whats this switch? next to storage kill switch. Looking4air Electrical - Systems, Generators, Batteries & Solar 1 06-28-2013 01:59 PM
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
Light Switch (Wall Switch) for 69 Overlander mbmbstreamer Lights - Interior & Exterior 3 03-21-2010 04:39 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
“Appliance selector switch” TRAPEZE Airstream Motorhome Forums 7 07-30-2002 05:32 AM
