Old 11-12-2003, 06:31 PM   #1
aviontt's Avatar
, Connecticut
Walnuts........
Has Anyone ever sand blasted an Argosy with crushed walnuts? I know this is a low distortion way of blasting fiberglass...Just wondering if anyone has ever done an Argosy this way.....
aviontt is offline   Reply With Quote
Old 11-12-2003, 06:37 PM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Walnut hulls less heat than sand but the best is plastic beads, I know it won't hurt automotive panels. I do auto collision repair. Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 11-12-2003, 06:42 PM   #3
aviontt's Avatar
, Connecticut
Where does one acquire Glass beads....and how is the clean up? Jeff
Old 11-12-2003, 06:43 PM   #4
LOST , Hawaii
I used fine sand to sandblast mine, it worked great and beat a da around a few thousand rivets.
John
74Argosy24MH is offline   Reply With Quote
Old 11-12-2003, 06:45 PM   #5
1979 30' Argosy
You will have to check with an automotive paint supplier or a body shop. Or with a sand blasting company.
Marivn
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 11-12-2003, 06:45 PM   #6
aviontt's Avatar
, Connecticut
What about sealing the panels after...
Old 11-12-2003, 07:27 PM   #7
Tinsel Loaf's Avatar
Use Crushed corn husks. Crushed Corn husks are used to clean log homes because it will not damage the logs which causes wood fraying. Corn huskd will make logs look like new. It should also clean fiberglass or aluminum leaving a clean surface with no damage.
Tinsel Loaf is offline   Reply With Quote
Old 11-12-2003, 09:30 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
aviontt -- Are you trying to get how deep into the finish? See this thread for another recent discussion on the topic. LOL
5 meter Langford Nahanni
Old 11-13-2003, 05:31 AM   #9
aviontt's Avatar
, Connecticut
The end cap have some very light rust. I would also like to remove all the paint I have sandblasted truck frames and the like I know about the heat problem The big issue to me is the resealing process also witch would be better walnuts or plastic...
Old 11-13-2003, 07:18 AM   #10
LOST , Hawaii
Fine blasting sand really will work with no problems. This is a shot fairly flat down the lh front corner of my mh, you can see there was no distortion. The paint comes of very easy, it's not like having to stay in one place like cleaning rust off a frame. Use a large diameter nozzle and keep moving, it will peel right off.
By sealing do you mean primer? If so it has to be zinc oxide, the galvanized caps and aluminum won't take regular primer. I used a primer surfacer over that to help seal around the rivets, then the color coats.
John
Old 11-13-2003, 08:40 AM   #11
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
You may want to contact Charlie Burke - American Way
RV - an Airstream dealer in Idaho - he used baking soda blast on his Argosy - turned out beautiful
Ken J.
Ken J is offline   Reply With Quote
Old 11-13-2003, 08:53 AM   #12
1979 30' Argosy
Another thing to think about is it you use plastic and I think it is true with soda too is you don't have to tape anything off like glass as these products won't harm the glass and other things.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
