Old 12-05-2011, 12:17 PM   #1
Roadtoaster's Avatar
2006 28' Classic
Byhalia , Mississippi
Vicious attack
Returned home from a Thanksgiving trip to Topsail with one very dirty trailer due to rain going and coming. Noticed I had picked up some tar and what appeared to be white paint. Washed the trailer Saturday and the white paint wouldn't come off, no matter what I used. Obviously its not paint, I have been attacked by the dreaded filiform. The funny thing is it is only showing up on the panels under the front window and the LP tank (so far anyway). I already had a little around the battery box frames but wasn't too concerned. Now I'm really concerned. Waxed the infected area real good and will conitinue to do so in hopes of stopping a serious epidemic. I have a lot more reading to do here on the subject but any suggestions or comments are welcomed.
Greg
(formerly known as ptrvr)
Roadtoaster is offline   Reply With Quote
Old 12-05-2011, 12:46 PM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I've used Bioshield and corrosionx and it does kill it. It turns from white to grey and doesn't seem to be spreading anymore. Good luck! I hate that stuff.
Brad and Zell
blmitch5 is offline   Reply With Quote
Old 12-05-2011, 02:15 PM   #3
dznf0g's Avatar
Oswego , Illinois
I'm lucky, only a couple of small spots. I did pick up some CorrosionX but haven't applied it yet.
Did you just spray it on and let it soak in? Do you need to make a pinhole in the clear to let it soak in?
"All I want in this life of mine..... is some good clean fun" - Little Feat
Old 12-05-2011, 02:32 PM   #4
blmitch5's Avatar
Olathe , Kansas
I would put a hole in the clear-coat. It's alot like wd40 (kind of runs) but I think it helps. The Bioshield turns into a waxy substance that stays on better but use it sparingly since its hard to get off.
Brad and Zell
Old 12-05-2011, 02:51 PM   #5
dznf0g's Avatar
Oswego , Illinois
Which do you like better? Chris Birch pointed me to the CorrosionX. He didn't say why.
Old 12-05-2011, 03:17 PM   #6
Wayne&Sam's Avatar
2007 20' Safari SE
Cuddebackville , NY
Every spring and every fall I spray Corrosion-X on the corroded spots and wipe with a rag. I doesn't seem to be getting any worse, but who knows why.
Old 12-05-2011, 04:13 PM   #7
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Corrosion-X will stop corrosion and is approved by the FAA for use on aircraft. We use it all the time on our aircraft. I spray the inside of our plane every year. It is cheap insurance.
gaylejoe is offline   Reply With Quote
Old 12-05-2011, 04:20 PM   #8
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Just spray paint the whole damned thing Greg.
We can all help after bourbon tasting at the CanOpener.
"Only dull people are brilliant at breakfast - Oscar Wilde"
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 12-05-2011, 04:23 PM   #9
dznf0g's Avatar
Oswego , Illinois
Good enough reason for me!
Old 12-05-2011, 04:23 PM   #10
dznf0g's Avatar
Oswego , Illinois
OK, a second good enough reason....
Old 12-05-2011, 04:48 PM   #11
2006 28' Classic
Hmmm, I must have missed the announcement for this year Dale. But, I'm flexible and will adapt
Appreciate everyone's comments about fixing this problem before it gets out of hand. Looks like a regular treatment of CorrisionX is the ticket.
Greg
Old 12-05-2011, 05:57 PM   #12
Cracker's Avatar
2000 30' Excella
Pittsfield , Maine
Nail Polish
I hate to promote something so simple, but I've had great success stopping minor filiform with the clear nail polish that the women use for "strengthening" their nails. Admittedly, I'm one of the lucky ones that has had almost insignificant problems.
Cracker
Cracker is offline   Reply With Quote
Old 12-06-2011, 08:17 AM   #13
dowpells's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
What the heck is filifoam? I get from the 1st post that it looks like white paint...but, what is it?
dowpells is offline   Reply With Quote
Old 12-06-2011, 08:35 AM   #14
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Corrosion problems with new Airstreams
SilverGate is offline   Reply With Quote
My Life with Henri (or Taming the '74 Sovereign) Aage 1974 Sovereign 131 10-16-2011 09:39 AM
Renovation sequence of events (or plan of attack!) kdenault General Repair Forum 2 08-18-2011 05:28 PM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
