12-11-2013, 03:04 PM
Oswego
Stainless steel water fill doors...
to replace the late model plastic ones are now available by calling AS. Not on the website yet.
I ordered mine today, albeit sight unseen.
-Rich-
12-11-2013, 03:25 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
So How much did it cost?
I have the furnace and water heater cover, might want to add this.
Paula
12-11-2013, 03:34 PM
Oswego
Get ready.......$185!!!!
-Rich-
12-11-2013, 03:37 PM
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina
, North Carolina
Holey Moley !
12-11-2013, 03:44 PM
Oswego
Yeah, It should be here by Monday or so...maybe yet this week. I'll let you know how it looks. From description, it is pretty much a duplicate of the original with the 2 pipe fittings, screen for the vent, an inside cap and 2 gaskets??? Presumably one for the skin and one for the door.
If it is quality, I can see a lot of hand work and welding, so I guess the price is to be expected. I'd really like to have the SS wrap compartments, but I had just gone to the trouble to strip, sand and refinish my peeling and corroded ones before they came out.
-Rich-
01-01-2014, 09:23 PM
1976 27' Overlander
Tampa
Hey Rich- how did the water fill work out? Can you post your review and pics? I'm in need of upgrading my old 1976, and have been waiting for this to be available. $185 bones for a fill door... whoa!
Thanks!
Micky
01-01-2014, 10:42 PM
AlaskaSafari
1997 25' Safari
Fairbanks
, Alaska
Originally Posted by Silverbee
Holey Moley !
I'll second that. Wow. I wouldn't mind replacing the plastic fill door, but at $185 I might have to think about that a little more.
01-02-2014, 10:27 AM
Oswego
Thanks!
Micky
Hi Mickey,
I won't be installing the door until spring when I get the AS out of storage, but here are some pics. It is a well made, high quality piece with a gasket on both the door and for the skin/door frame interface.
I did seal some areas which I felt could allow water behind the skin when I overfill the FW tank.
I sealed the seam all around the perimeter, the hose neck, the vent neck and the two rivets which hold the anti-spin fill neck brace. I used Par-bond.
-Rich-
01-02-2014, 12:15 PM
2012 30' International
Bad Axe
, Michigan
Great! We have replaced the furnace, range exhaust and outdoor shower door. I have always disliked the plastic water fill door.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
01-02-2014, 12:16 PM
Bad Axe
, Michigan
Also water heater.
1947 Spartan Manor
03-24-2014, 08:18 AM
Bad Axe
, Michigan
Has anyone actually installed this? We have had ours for awhile now but the weather has been too cold to do anything about it.
1947 Spartan Manor
03-24-2014, 08:35 AM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Installed mine (and water heater door, furnace door, vent, outside shower door -- I've gone all SS), and it works fine. Bit of a hassle to install as I had to do some minor trimming on the panel so it'd fit correctly. Looks so much better.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
03-24-2014, 08:53 AM
Bad Axe
, Michigan
By trimming do you mean on the trailer? Did you run into any problems with the water hookup?
1947 Spartan Manor
03-24-2014, 11:31 AM
2015 30' Classic
Greensboro
, North Carolina
I had to trim a bit of the panel on the trailer, wasn't a big deal. No problems at all with the water hookup. Used the trailer for about 10 days in January (FL), multiple hookup occasions. Zero issues.
_________________
ProPride 3P
AIR# 58452
03-25-2014, 07:50 AM
1973 21' Globetrotter
Houston
Just what I was looking for--but they look to be sold out directly from Airstream. Anyone know if they are available anyplace else?
03-25-2014, 08:05 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
My stainless steel water door hatch came with a CH708 key instead of the ubiquitous CH751 key that all RVers have for water access. This lock mechanism can not be rekeyed due to it's construction (CHEAP).
In their infinite wisdom, the factory has installed a new lock mechanism for the 2014 models outside access hatches. They are all keyed to the CH751 key. Thus anyone can open the access hatch and push up on the mattress or cushion and gain access to the inside of the trailer. The dead bolt and lock on the door are bypassed.
I found a locksmith that could alter these new access hatch key tumblers, so I made them match a lock on the camper shell of the pickup. That makes for one less unique key to carry.
I imagine a screw driver given a big twist would break the lock anyway, but the honest folks are deterred.
03-25-2014, 10:25 AM
Bad Axe
, Michigan
Thanks. I f I remember correctly, we had to do a bit of trimming when we replaced the outside shower.
1947 Spartan Manor
03-25-2014, 10:33 AM
Battle Lake
To get past the locks, they would just break a window. They don't like crawling through little access doors. The best theft protection is good insurance.
I don't care for my plastic water door access. Would my old lock mechanism fit the new stainless door?
Doug and Cheryl
03-25-2014, 12:58 PM
2015 30' Classic
Greensboro
, North Carolina
Sorry, it won't fit. (I thought about doing this myself, but the mechanism is a different size).
_________________
ProPride 3P
AIR# 58452
10-27-2014, 08:33 PM
1976 27' Overlander
Tampa
Hi Mickey,
Attachment 202756
Attachment 202759
Attachment 202763
Hey Rich- just going back through some posts and came across this one. Im about to the point where I "should" be doing my water fill....
Just wanted to check in to see how this went? Did you install and did it go ok? Any feedback to dimensions, issues, positives and negatives is appreciated.
Thanks!
Mic
