Old 03-25-2014, 07:50 AM   #15
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Just what I was looking for--but they look to be sold out directly from Airstream. Anyone know if they are available anyplace else?
Old 03-25-2014, 08:05 AM   #16
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
My stainless steel water door hatch came with a CH708 key instead of the ubiquitous CH751 key that all RVers have for water access. This lock mechanism can not be rekeyed due to it's construction (CHEAP).
In their infinite wisdom, the factory has installed a new lock mechanism for the 2014 models outside access hatches. They are all keyed to the CH751 key. Thus anyone can open the access hatch and push up on the mattress or cushion and gain access to the inside of the trailer. The dead bolt and lock on the door are bypassed.
I found a locksmith that could alter these new access hatch key tumblers, so I made them match a lock on the camper shell of the pickup. That makes for one less unique key to carry.
I imagine a screw driver given a big twist would break the lock anyway, but the honest folks are deterred.
Old 03-25-2014, 10:25 AM   #17
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Thanks. I f I remember correctly, we had to do a bit of trimming when we replaced the outside shower.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 03-25-2014, 10:33 AM   #18
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
To get past the locks, they would just break a window. They don't like crawling through little access doors. The best theft protection is good insurance.
I don't care for my plastic water door access. Would my old lock mechanism fit the new stainless door?
Doug and Cheryl
Old 03-25-2014, 12:58 PM   #19
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Sorry, it won't fit. (I thought about doing this myself, but the mechanism is a different size).
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 10-27-2014, 08:33 PM   #20
Mixter's Avatar
1976 27' Overlander
Originally Posted by dznf0g View Post
Hi Mickey,
I won't be installing the door until spring when I get the AS out of storage, but here are some pics. It is a well made, high quality piece with a gasket on both the door and for the skin/door frame interface.
Attachment 202756
Attachment 202759
I did seal some areas which I felt could allow water behind the skin when I overfill the FW tank.
Attachment 202763
I sealed the seam all around the perimeter, the hose neck, the vent neck and the two rivets which hold the anti-spin fill neck brace. I used Par-bond.
Hey Rich- just going back through some posts and came across this one. Im about to the point where I "should" be doing my water fill....
Just wanted to check in to see how this went? Did you install and did it go ok? Any feedback to dimensions, issues, positives and negatives is appreciated.
Thanks!
Mic
Mixter is offline   Reply With Quote
Old 10-27-2014, 08:39 PM   #21
dznf0g's Avatar
Oswego , Illinois
Hi Mic,
Just a straight bolt on. No trimming or mods to the AS required. I did seal around the perimeter with Parbond.
-Rich-
Old 10-27-2014, 09:13 PM   #22
Mixter's Avatar
1976 27' Overlander
Ahh.... you are direct replacement. I will be retro fitting to my '76 which has the terrible water fill.... I'm guessing it just takes a little trimming to accept the newer, larger size.
Thanks for the quick reply!
Mic
Old 10-27-2014, 11:12 PM   #23
mefly2's Avatar
2015 25' FB Eddie Bauer
Winter weather has hit here ... will wait until it warms or spring hits to install our SS WD.
Old 10-29-2014, 03:52 PM   #24
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
I need to look into some SS upgrades....right now (IMO), the look of the stove vent is the worst offender followed by the water heater. Is there a preferred third party reseller that is (more) reasonably priced or just straight from AS?
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 10-29-2014, 04:59 PM   #25
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Mic
If you are ditching the original tip-back door, you might consider offering it up for parts to someone. These can be rebuilt with fiberglass if cracked and are awesome for bucket filling when boondocking.... It took me months to find one when I was looking.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-29-2014, 05:52 PM   #26
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Water Filler Door
Still can't believe the hinge is on the wrong side!! When will Airstream learn doors should trail in the wind.
fltlevel510 is offline   Reply With Quote
