12-08-2006, 09:51 AM
Old Paint, rolling again.
1973 Argosy 20
Lorain County
, Ohio
Spray polyurethane foam insulation
Hey all, I know that this horse has been beaten to near death but... for the cause of science I thought that I would throw out another INSULATION idea for your consideration: Quick curing two-component spray polyurethane foam insulation.
It's the stuff that you've seen used on PBS's This Old House. They spray it into the open stud bays where it sticks and immediatly begins to expand. Usually they spray it on thick enough where it expands beyond the face of the studs and is then cut off flush to the wall surface. In an older home renovation the benefit is that it seals the walls and acts as a moisture "resistant" barrier. I may use it on the house we are about to purchase, a century home with plaster walls and no insulation. The foam can be sprayed (or poured ?) through small holes into the wall cavity where it rises and fills it up providing R-7 per inch of wall thickness.
On an Airstream perhaps spraying 1 inch thick into the open wall and then adding foil would be a good use? It's not cheap but it will provide another layer agains water penetration, provide more soundproofing, it's non-offgassing, and mold doesn't like it
Also could an ideal use be for insulating under the floor?
This is the only DIY distributor I've found so far. Good web site with lots of tech info and FAQs answered.
Tiger Foam Insulation
By the way, the trade name is ICYNENE
Merry Christmas!
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
12-08-2006, 10:00 AM
Silver Mist
Riverhead
, New York
Let that horse die. the 1/4" foil bubble is the new horse
12-08-2006, 10:09 AM
Jupiter
For non-sprayable foam Urethane Foam , Expanding Marine Polyurethane Foam
I'd like to see someone apply .25" spray foam on the liner panels only...
The spray-on is pretty neat stuff, shame I haven't won the powerball...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
12-08-2006, 10:10 AM
Corona
Steve
Houses don't move. Trailers and motorhomes do.
The twisting of the shell or body, in time, will grind the spray on foam insulation to a powder.
Airstream tried in in the doors of the early 69 models.
It was an absolute failure.
12-08-2006, 10:20 AM
2006 30' Classic
Farmington
, New Mexico
I've use the spray foam to help "mouse proof". I used it to fill lots of nooks and cranies. I read somewhere else they will knaw through it.??? the jury is out but so far no mice. "I hate those meces to pieces"----pieman
12-09-2006, 06:04 AM
1973 Argosy 20
Lorain County
, Ohio
...Airstream tried in in the doors of the early 69 models. It was an absolute failure....
I'm not shot down that easily...recall this is for the cause of science. Also, I bet the technology has changed maybe a tad in the last 40 years. I remember that old foam would turn to dust with age even without abuse. I plan to set up some tests when I order the product next summer.
Steve
12-09-2006, 07:09 AM
1994 30' Excella
Milwaukee
, Wisconsin
I recently had an estimate to insulate the house with foam, while he was there I asked about Chummy. This product goes in with existing Fiberglas insulation and expands around it to fill the cavity. The installer said it would work and would guarantee the product not to break down. However, the cost was three times what regular blown insulation would be for the house and he did not give me a price for Chummy.
Chaplain Kent
Forest River Forester 2501TS
12-09-2006, 07:20 AM
1994 30' Excella
Mississauga
, Ontario
One downside to spray in place foam is that in the event of any damage(dents etc), it makes removal and repair much more labour intensive.
As for vapour barrier the glue laminations in the plywood floor are an effective barrier by themselves.
Also if any condensation or other moisture was to find its way between foam and adjacent surface it would not escape easily.
I have a related question for those who have had their belly pans off.
Is the fiberglass insulation fastened up to the underside of the floor ply or does it rest on the belly pan?
Al
12-09-2006, 07:42 AM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
I used that foam in a can on engine hood for Suburban.
The two metal sheets had separated making a tin can sound and a 'ding' when the hood was closed.
After adding foam it is solid unit.
Slams shut with a very nice thud.
Did this 5 years ago..zero grinding and is still holding panels tightly together.
12-09-2006, 07:51 AM
Corpus Christi
I'm reluctant to add fuel to this fire, but in the interest of science, I feel I need to add some additional considerations. When I was an active architect, I seem to remember something about urethane foam insulation posing two problems. First, if my memory serves me correctly, it off gasses urea formaldehyde for some time after placement. Some people are very sensitive to formaldehyde, causing nausea and vomiting. Second, in the event of a fire, it can give off fosgene gas and other toxic gases which can be deadly. Also, it can add fuel to a fire, which fiberglass insulation does not do. For commercial buildings, it is almost impossible to achieve required fire safety ratings for assemblies using urethane foam. That said, there are expanding foam urethanes as comes in those cans you see at Home Depot. These tend to be fairly flexible and contribute no structural strength.
Then there are expanding structural urethane foams as can be found here: Fiberglass , Epoxy , Composites, Carbon Fiber - U.S. Composites, Inc. These are they types of urethane foam used in surfboards and such. They come in different densities, are closed cell so they don't absorb water, and would be very much up to the task of making a door rigid. Airstream may or may not have used their best and brightest engineers on that experiment. The urethane I've been using on windsurf boards would have made those doors rigid, light, and ding resistant. One of the upsides of urethane foam is it acts like a glue, bonding to most materials.
So Long!
12-09-2006, 08:19 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Al
In my 1975 and 1980...both There is a 3" layer that is paper faced that is laid in place from above the frame, then there is a layer of unfaced that was apparently laid in place prior to the belly skins being installed. If you have ever seen pictures of the Airstream plant, they install the floor on the frame first, then flip the chassis over and install the belly pan...at least that is the way they used to do it.
Aaron
WBCCI #XXXX AIR #2495
12-09-2006, 10:01 AM
1976 25' Caravanner
Campton
, New Hampshire
This is for informational purposes only . I have a 12'x8' military enclosed trailer that I converted into a construction trailer. The walls ,floor and ceiling (roof) are all aluminum with 2" of foam(I think urethane) sandwiched between the inner and outer aluminum . The frame is aluminum I channel. This trailer was ment to travel on the ruffest of terrain . During the conversion I have taken some of the panels apart and there was no break down of the foam . This trailer was made in 1959 . I would think from this observation that the technology for the proper foam exists.
12-09-2006, 11:49 AM
1973 Argosy 20
Lorain County
, Ohio
Foam home
Originally Posted by Bob Thompson
...it off gasses urea formaldehyde for some time after placement.... For commercial buildings, it is almost impossible to achieve required fire safety ratings for assemblies using urethane foam.
TIGER FOAM Insulation has NEVER contained Octa or Penta BDE's or VOCs, CFCs or Formaldehyde. We have, from the beginning, used ONLY the safest and most environmentally friendly fire retardants.
I think that "GREEN" building technologies have come a long way. I am sensitive to chemicals so avoid them at all costs.
Yes, It's expensive but in an older house there is no other way to provide the moisure barrier short of removing the interior walls, or the exterior clapboards. I'm estimating that I will be able to do nearly the whole house myself for the cost the installer quoted for just the attic....which is still 3 times the cost of blown insulation. BTW, the technical literature claims that the open cell foam will allow the movement of moisture through it, much like Tyvek house wrap does.
Thanks to all for keeping this discussion alive. It is certainly worth exploring even if it's not ideal for every application.
Steve
12-09-2006, 12:58 PM
1976 Argosy 24
now being enjoyed by Heath and Mary in
, Vermont
Why would anyone hold up an example from 1969?
It’s obvious that there has been tremendous technological advancement in components and methods since then.
Giant intercity buses, now made of composite materials instead of aluminum, have foam sandwich insulation.
Many advanced motorhomes made in Germany also use similar materials and techniques.
Wiltsie Truck Body, were some of my Argosy renovation takes place, uses sprayed-in foam in trailer building all the time. Wiltsie is a 55 year-old family company that knows what it’s doing.
The difficulty of spraying foam in place in an Airstream or Argosy is, I think, that the ribs in the trailer run both vertically and horizontally.
At Wiltsie, they spray the foam in place between the ribs, level and carve off any excess, and then apply the interior skin.
I didn’t use spray insulation but I wish now that I had.
Some people have mentioned the wiring harnesses, suggesting foam would make later servicing difficult. I think that is of small concern, when judged against how superior a foam insulating job can be.
Sergei
12-09-2006, 01:53 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Foam....Now your talking.
As a firm believer let me add.....
I live in a SIP built house. (call it Structural (or Stress) Insulated Panels.) Foam panels.
Its Structural...and provides the best possible insulating value.
Outgassing is a myth.
Fire provides no more danger than any other home material.
I also had spray insulating foam put on the walls and ceilings of all my barns and shops. It absolutely cut moisture and rodent problems to zero. Temp in both summer and winter is easily stabilized....the walls strengthened, and most external sounds blocked out.
Insulated railroad cars and over the road truck trailers use the foam...have for years...and I have not heard of a disintegration problem from flexing and vibration.
I would bet that skin dents would be minimized with a foam inner bond too. If I could get one of those abandoned Airstreams out of the woods near me for a CHEAP price I would be willing to foot the costs of an experimental go at foaming a rehab. I have faith in it.
12-09-2006, 02:10 PM
Originally Posted by SmokelessJoe
. . Some people have mentioned the wiring harnesses, suggesting foam would make later servicing difficult. I think that is of small concern, when judged against how superior a foam insulating job can be.
Sergei
It's not that hard to put in plastic conduit, then you don't need to worry about the wiring either.
I almost wish I had mine sprayed. I know a lot of small boats use spray in foam, and they shake more than an airstream.
12-09-2006, 02:34 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
Foam...
Barry (of the huge ultradollar Spartan car hauler) used it in his remodel. Even after the crash, I don't believe he had any problems with it.
As far as wiring - I would think that the foam would actually help protect the wiring from fraying against the metal ribs. If it wasn't so expensive, I'd think about using it if/when I pull the interior skins.
Marc
12-09-2006, 04:55 PM
We've sprayed urethane CLOSED cell foam in cargo trailers with no problems. It is a more rigid system, it does not expand as much, and provides R-7 per inch. That Tiger foam is the same stuff I'm talking about.
Icenene (open cell polyurethane) will absorb water.
sprayfoam.com can give you more answers.
12-09-2006, 05:04 PM
Remember, Safety Third
Catfish Corners
, Georgia
OK, I'll bite on this one and chew for a while.
My Brother-in-law (great start, right?) is in the process of adding an entire 2nd floor to his ranch home in FLorida. He had a company spray this stuff in the attic--agianst the roof, not the floor of the attic. He aslo had it sprayed on under the floor between the two floors of the house. It is anywhere from 2 to 8 inches thick, depending on the location. He loves the stuff. It does block a lot of outside noise and is a great insulating material. As others have pointed, as well, it is on the pricey side.
I want to go back and re-read a few posts here--and see what name brands people are thinking of. I'll check back in a while after I read more....maybe prices have come down enough to consider this. I'm at the point where I'm ready to start putting insulation back in.
12-09-2006, 06:37 PM
Catfish Corners
, Georgia
OK, so a rough estimate--here goes:
I have a 27 foot trailer. It is roughly 23.3 feet long on the interior. The floor-to-floor measurement of the shell is roughly 18.6 feet (measuring up from the floor, across the ceiling, back down to the floor). This is about 433 square feet.
Subtract out the windows, etc, and that leaves around 400 square feet to spray. The walls are about 1.5 inches thick. The TigerFoam kits come in two standard sizes, 200 and 600 square feet @ one inch thickness of the spray. The 600 square foot kit would look to be about what I need. And at $650 (around $1.00/ square foot) this is beginning to look doable. I’m looking at prices of 50 to 75 cents per square foot for the foil insulation. Plus the cost of the tape to tape it together, foam strips to set it back from the walls, glues to hold the foam strips up, etc, etc.
OK, this is beginning to look really good now.
So, more questions. The TigerFoam website claims this stuff is “closed cell”. That means that it won’t absorb or retain water. Is it also true that it acts to seal water out? I’m looking for an excuse not to have to replace the all of the Vulkem on the interior. What happens to any water that does seep in between the foam and the aluminum skins? What about water condensation? There’s more than a few threads here debating the hows and wheres of that subject. Where is the condensation likely to occur in this type of application? On the interior walls, the part that faces you when you stand in the trailer, or in between the inner and outer skins, around the foam?
All or most of the wiring would have to be placed in some kind of conduit. Mark, didn’t you use a flexible conduit on your rebuild? What type and how expensive was it? I’m about 1/3 of the way complete cleaning and inspecting the original wiring in mine and I have to say it is still in excellent shape. There was only one spot around the water heater that needed to be repaired (so far).
So, what am I missing here? Time to read more.
