Old 03-17-2006, 11:57 AM   #1
AnnabeltheCaravel
chalcedon's Avatar
1967 17' Caravel
Spray insulation
Hello.
Has anyone ever used spray insulation when doing a full restoration to replace the fiberglass stuff. I,m completely rebuilding our 67 caravel and would like to know if there is any type of spray insulation (commercial grade)
that is recomended.
Thanks.
Eric in Vancouver B.C.
chalcedon is offline   Reply With Quote
Old 03-17-2006, 12:12 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
My brother-in-law just used this stuff to do an addition to his house and has tried to talk me into using it in the camper. One drawback is that is expensive. Another is that it would completely fill the walls. I've also wondered how it would stand up to the movement of the trailer. One the other hand, it's supposed to be a very good insulator.
Maybe somebody with actual experience will chime in.
www.nesa.org
Air No. 6427
Old 03-17-2006, 12:47 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
It is my understanding that if you use it in an Airstream, it will eventually pulverize due to the amount of movement. And I am sure that cost is a major issue too, especially from a production point of view.
Aaron
WBCCI #XXXX AIR #2495
Old 03-17-2006, 03:17 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Weight
The spray-in stuff, in my limited experience, appears to be much heavier than batt insulation. In a house, no big deal. But in a travel trailer it may add a lot of weight.
Tom
Old 03-17-2006, 03:32 PM   #5
New Borockton , Alabama
Images: 21
Are you talking about the wet foam stuff that hardens or the blown in kind used in wall and attics?
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 03-17-2006, 09:03 PM   #6
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I have used the spray insulation to push out small dents and then to keep the dent from falling back in. After a couple years of having it in place I removed part of the panel and it was still in place with no noticeable pulverization. Keep in mind that when you do use this product the panels will no longer have movement but be rigid.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 03-17-2006, 09:37 PM   #7
cameront120's Avatar
1972 25' Tradewind
Welcome Eric from a fellow Vancouverite (well, North Vancouver). The rigid foam insulation does give you greater R-values in less thickness than fiberglass batt insulation, but it is heavier and it can lose insulating value if wet. The other problem I see is that it's permanent (or at least very hard to remove), so if you need to repair wiring or plumbing that gets coated with the stuff, you could be in for a real time of it. The fiberglass batt insulation will be a lot easier to work with. Fiberglass isn't the best or most high tech insulation, but it performs adequately and predictably.
Cheers!
North Vancouver, BC
Glass windows; insulation smallfry Windows & Screens 5 01-10-2003 05:15 PM
is the insulation flammable ? oldvws General Interior Topics 3 12-31-2002 11:12 AM
Insulation Cat General Interior Topics 6 11-26-2002 06:31 AM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
Plasticoat vs. Clearcoat spray...?? HappyChi Clearcoat, Exterior Paint & Trim 9 08-12-2002 06:13 PM
