Old 08-16-2014, 12:47 PM   #1
cincinnati , Ohio
Soft Roof
I just purchased an 02 26 ft Land Yacht Motorhome. When installing a satellite dish I noticed the roof above the driver to be " soft ". At first I thought it was rotted but after finishing mounting the reinforcement plate I realized the fiberglass roof had separated from the wood it was glued too. The wood underneath seems solid. I'm wondering if I should drill some small holes ( oh No ) in the roof and inject some glue to solidify that section again. It extends about one foot from the edge and rearward three feet. ANYBODY BEEN THERE DONE THAT??
Navin
Navinjohnson is offline   Reply With Quote
Old 08-16-2014, 12:56 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Well. Not on a roof of an AS, but on a SOB! And in my own floor..
Here is what I used both places
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-16-2014, 02:48 PM   #3
cincinnati , Ohio
soft roof
Is it injectable with a large syringe?
Old 08-16-2014, 03:17 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yes. I drilled 1/8 holes all over in repeating pattern as you can see in picture. I started at the "solid" edge drilling g then filling. Drilled half depth or less. If I hit good wood I stopped. Do not drill all way through!!! Duh moment.
Inject from solid toward loose edge. Let it wick into pores. Pour remainder over top and "work into surface.
Did same in bass boat deck. Taped concentric circles from loose area by deck pedestal then marked tape and drilled through tape at those spots. Injected at each drill hole. The tape was lifted quickly after injection so minimal sticking to tape. Without tape we would have never found drill holes to inject.
One year and still fishing!
Channing
WBCCI# 30676
White roof is soft beulahluster Roof 6 08-20-2009 09:07 AM
What to use to keep window seals/rubber soft. Safari-Rick Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-27-2006 06:24 AM
How do I diagnose the soft spot, and what are the repair options? Narnian Repairing/Replacing Floor &/or Frame 12 09-01-2003 02:41 PM
soft spot repair stellablu Repairing/Replacing Floor &/or Frame 2 08-08-2003 03:18 PM
Soft floor kenny2 Repairing/Replacing Floor &/or Frame 2 01-19-2003 06:21 AM
