Old 11-24-2005, 07:10 AM   #1
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Skin Replacement 68 Safari
Last weekend Murray ( Creampuff) and I tackled the long overdue streetside skin replacement on his 1968 Safari. The sheet was damaged, and one of the vertical ribs was also bent by a minor accident the trailer had suffered. We're not going to elaborate how this happened, to protect the innocent.....
In any case, here the first pictures, of the trailer's damaged body.
Name:	STREETSIDE DAMAGE.jpg
ID:	16608   Click image for larger version
Name:	S.S. BEFORE.jpg
Uwe
www.area63productions.com
Old 11-24-2005, 07:30 AM   #2
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Skin removal
First, Murray cut a bunch of rivets with a chisel and putty knife, while I drilled out osme of the more critical ones, around the windows etc.
ID:	16611   Click image for larger version
Uwe
Old 11-24-2005, 07:31 AM   #3
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Sheet gone!
Here are a few images of the partially undressed Safari.
Due to the graphic nature of these pictures, parental guidance is advised!
ID:	16614   Click image for larger version
Uwe
Old 11-24-2005, 07:41 AM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Yiks - Airstream nudity on the forums........
Looks great so far........
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-24-2005, 07:43 AM   #5
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Surgery
We found that one of the vertical ribs had sustained some damage when Murray hit the wall with the trailer the second or third time, I forgot which time it happened...ooops, we were going to keep this classified information....ahem...in any case, a sister rib was fabricated, and carefully grafted onto the bent section of the original rib. We copied the curvature fom an existing, yet undamaged, rib.
ID:	16617   Click image for larger version
ID:	16619   Click image for larger version
Uwe
Old 11-24-2005, 07:47 AM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Rib repair
2 more pictures that got swallowed by cyberspace during the last post
ID:	16622   Click image for larger version
Uwe
Old 11-24-2005, 07:53 AM   #7
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
In the meantime, the old sheet was cleaned up for use as a template to cut the new metal.
We decided to use 032 Alclad, as the entire bottom of the sheet wraps in to form the lower rounded edge of the trailer. It joins the belly pan at about 4in under the trailer. 040 would have been a bear to bend.
Name:	sht. dismount.jpg
ID:	16624   Click image for larger version
Name:	SHT. REMOVED.jpg
Uwe
Old 11-24-2005, 07:57 AM   #8
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Cutting the new sheet after the pattern was transferred to it from the old sheet.
Name:	CUTTING NEW 2024.jpg
ID:	16627   Click image for larger version
Name:	TRANSFER PATTERNING.jpg
Uwe
Old 11-24-2005, 08:01 AM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Install/seal
The freshly cut sheet was first fitted, then trimmed in a few placs, and finally secured with clekos. Next time the Vulkem goes on after fitting and cutting the sheet, keeps people from looking like walking vulkem catridges.
Name:	FINAL ALIGNMNT.jpg
Uwe
Old 11-24-2005, 08:06 AM   #10
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Next step was installing the sheet with Olympic rivets, applying yet more Vulkem here and there,and around each and every rivet hole. Each rivet got a small amount of Vulkem around the rivet shaft. We want no leaks!
Name:	TIME FOR OLYMPICS.jpg
ID:	16631   Click image for larger version
ID:	16633   Click image for larger version
Uwe
Old 11-24-2005, 08:12 AM   #11
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Cleanup time
Murray immediately got busy cleaning up the exces Vulkem around all the rivets and seams. He ended up using acetone and paper towels.
Name:	VULCUM CLEANUP.jpg
ID:	16636   Click image for larger version
Uwe
Old 11-24-2005, 08:16 AM   #12
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Time to shave
Now, all the rivets got a close shave courtesy of a rivet shaver borrowed from Glyn. Thanks, Glyn!
The finished sheet installation looked very straight and clean. It got late, so we did not take pictures of the wrap procedure. But the job did get finished in one day, and we were both quite pleased with the outcome.
ID:	16639   Click image for larger version
Name:	TIME TO SHAVE ?.jpg
Uwe
Old 11-24-2005, 08:19 AM   #13
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
No Drill Here!
btw., there are wires right underneath the skin, one should know where they run, and take note before drilling for new rivet holes.
Sorry, this photo is upside down.
Uwe
Old 11-24-2005, 08:42 AM   #14
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Nice work and great pics.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
