Old 05-05-2013, 02:42 PM   #1
Bayfield , Colorado
single main door hinge for '67 Overlander
The door hinge on my 67 airstream overlander is damaged. Possibly it could be straightened and made usable - once the pin is removed - but was wondering if anyone knows where I could find a replacement.
Also any advice on riveting the hinge back on to the door and body.
thanks
bob
roolshedbob is offline   Reply With Quote
Old 05-05-2013, 03:43 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
thanks
bob
Check your messages, you've got mail.
Old 05-05-2013, 05:18 PM   #3
thanks
bob
The hinge has been gone for almost 40 years.
But, a replacement pin, is available.
Old 05-09-2013, 03:47 PM   #4
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Give Airstream Supply in Seattle a call, he parts out old trailers and I'll bet he has that hinge available 877-686-7331
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 05-09-2013, 04:09 PM   #5
1963 19' Globetrotter
Moline , Illinois
Can you post a picture of the hinge?
63air is offline   Reply With Quote
Old 05-15-2013, 06:58 PM   #6
Bayfield , Colorado
Thanks to all of you for your responses. I got a replacement hinge from "out of doors mart" in north carolina. It was not the original hinge for that year - perhaps a latter model but I was able to make it work. It looked stronger than the original hinge and had 1/4" bolts instead of 1/8" rivets for attaching to body and door. All of the original rivets had snapped off my hinge and were replaced by 2 sheet metal screws when I got the trailer. Not surprisingly - the door fell off.
Thanks again,
bob
Old 05-15-2013, 07:35 PM   #7
Well Preserved
1993 21' Sovereign
Bob, that hinge was off a '68. Same body, same door, but the factory found an issue with the hinge, and corrected it. That's why the hinge you got was a bolt-on, rather than riveted.
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
Zip Dee main arm bars ThreeFingers Awnings 5 09-16-2011 12:11 PM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Need Door for 1961 Overlander BentMetal 1960 - 1964 Overlander 9 07-28-2011 04:36 PM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 02:50 PM
