Old 02-13-2014, 08:37 PM   #1
1959 22' Caravanner
Side Grinder vs. Polisher
Really confused about which polishing tool to buy. Seems logical to buy a "polisher" but they're hard to find in my area and expensive when compared to a side grinder of the same make. Thing is, a few of the "how to" videos and blogs that I really respect recommend...or casually mention...using a side grinder. My concern is, how do you hold a side grinder to 1800-3000 RPM when they all seem to be rated at 8000+ RPM? If its trigger control, I can't imagine doing that for 200 hours!
JimCat2000 is offline   Reply With Quote
Old 02-13-2014, 08:44 PM   #2
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
Great question! I'm curious for the opinions on this one!
albert is offline   Reply With Quote
Old 02-13-2014, 08:56 PM   #3
Mixter's Avatar
1976 27' Overlander
Hey JimCat2000- I went through the same dilemma. Ended up going the polisher route. Have about 7 years of experience detailing cars out of high school, and have always done my own vehicles ever since, I felt more comfortable with high speed buffer type, with a wool pad. I questioned what I would buy, as name brand goes, since my experience is with professional quality milwaukee, dewalt, etc. I went with the $29 Harbor Freight and have been pleased. If you want name brand, there is a milwaukee on C-list right now in Tampa for $135 -has been on there a while so maybe negotiable. I had some old wool pads, but not enough for this type of job, so I bought about a dozen on ebay from $4 bucks each.
For polishing compound, I think you'll see alot of different opinions, but I think Nuvite is the favorite. I had no idea what grade to buy, so I bought 1 of each. I thought I'd be able to polish with the finer grades, but I've got some oxidation that F9 seems to be the ticket. As I remove this layer, I may use the finer grades to get more out of it. Right now, I'm just wishing I have a consistent sheen... but I can see how trying to get the mirror can get addictive... so we'll see where that goes. I have SOOO much to do, that mirror is last on my list. I can always do that later. Right now the F9 is cutting through the oxidation just fine, and provides a HUGE improvement.
Harbor Freight is on Florida and Fletcher in Tampa. 25% off coupons come in the mail almost weekly if you look for them.
Here is what I bought: Sander/Polisher 7" Variable Speed
Reviews are mixed, but I think I paid $29 bucks and for that it was worth the try. It has done the job as good as my old pro quality buffers, so I am happy with it.
Contact me anytime for help or questions- I have hooked up with 3 other local Tampa guys restoring similar AS's and we have done some group purchases on misc items, and bounce ideas off each other.
Good Luck!
Mic
Mixter is offline   Reply With Quote
Old 02-13-2014, 09:01 PM   #4
Mixter's Avatar
1976 27' Overlander
This is the video that sealed the direction for me. F9, C, S with a wool buffer.
Airstream Planet - Polishing (Part 3) Grade F9 - Episode ??? - YouTube
Old 02-14-2014, 01:11 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If you have a trailer that was as oxidized as mine was, and you have a very good compressor, I recommend an air powered polisher.
IMO , an angle grinder turning 8K would be hard to control an maybe a bit dangerous. I have little doubt that at this speed it would be possible to get the aluminum hot enough to warp.
An air grinder is lighter, lots less arm wear than pushing an electric polisher or grinder over the surface of a trailer for forty hours.
Old 02-14-2014, 05:40 AM   #6
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
I used a Simonize Polisher from Canadian Tire ($149) with variable speed 600 - 6000 rpm
and the kit from Jestco Buffing Supply
Worked well for me
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 02-14-2014, 06:35 AM   #7
r carl's Avatar
Lin , Ne
You should get something like this buffer.
Milwaukee Tool 5540 7" Polisher 11 Amp Trigger Speed Control with Pads Accs | eBay
Old 02-14-2014, 06:41 AM   #8
r carl's Avatar
Lin , Ne
A wool pad wont stay on an angle grinder at that RPM and if it did you wouldn't be able to hold it.
An electric buffer-polisher is around 1700 RPM and it does look like an angle grinder.
Old 02-14-2014, 06:41 AM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have had the harbor freight polisher for quite a few years and find it quite satisfactory.
Final polishing is better done with an orbital polisher of some sort to get rid of swirls from the other polisher.
The expensive Cyclo is probably the best out there but the $35. orbital ones do alright too
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-14-2014, 07:42 AM   #10
Gilmurr's Avatar
I should add that I used a Cyclo polisher for finish work....which I will continue once out of storage...
David & Andrea
Old 02-14-2014, 09:53 AM   #11
1971 21' Globetrotter
Cave Creek , Arizona
Hey, JimCat, check out the website "Perfectpolish .com", this system worked great for
us .
"Money frees you from doing things you dislike. Since I dislike doing nearly everything, money is handy." Groucho Marx
snakecharmer is offline   Reply With Quote
Old 02-15-2014, 09:15 PM   #12
1959 22' Caravanner
Ok, based on everything I heard, I'm starting to think that even the experts may use the term "side grinder" and "polisher" interchangeably. I checked several variable speed side grinder at Lowes and Home Deport and they were all trigger control. I finally bought a Dewalt Polisher with a thumb wheel that governs the RPM from about 600 to 3500. Seems to work great so far, but I'm waiting for my Airstream kit from Jestco...Thanks, Levon! And thanks to all of you who chimed in. Mixter, we live just south of HB Plant high school. Our new '59 Caravanner is on the curb, gutted. Come by and see us! My cell is (813) 220-8601. James
Old 02-18-2014, 01:49 AM   #13
albert's Avatar
1970 29' Ambassador
1957 26' Overlander
Tulum , Mexico
Jimcat, be sure to send pics as you buff along. Thanks!
Old 02-20-2014, 04:40 AM   #14
1959 22' Caravanner
Will do. Actually, I may try and figure out how to "blog". There's a whole lot going on and I'd like to document it.
Side battery door on a '71 Overlander and rear twins. chilipepper General Repair Forum 8 07-07-2015 01:53 PM
1970 Ambassador curved side windows. Uppie89 Windows & Screens 4 07-01-2013 08:08 AM
Door on Left Hand Side. Any models? cazna Windows, Doors, Locks & Vents 7 02-10-2012 09:09 AM
2003 25 ft airstream safari needs work on side eBay Watch Airstreams on eBay 0 12-08-2011 09:40 AM
looking for 22' with equal size side windows.... turfclubroad 1980 Caravelle 7 01-07-2010 06:05 AM
