Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 01-06-2008, 02:36 AM   #1
catson4's Avatar
1991 34' Limited
Port Orchard , Washington
Segment repair or replacement---------maybeeeee
I am rebuilding a 1991 34' Classic Limitte dEdition.
The first photoshows what the the center front roof segment that is above the front window looked like this morning.
I am trying to repair this myself as the replacement cost would be almost $900.00 ( $600.00 plus about $250.00 for freight because a crate is required and the "volume weight" rates that apply).
The second photo shows what results I got after only 30 minutes of "rolling" the roof from the inside. and I am not done yet.
This was "rolling" done without using a backer block. We shall see what we see tomorrow.
The third photo is of the roller I mad from three 3" casters welded to a pipe handle.
Name:	Copy of DSC_0090.JPG
ID:	52069   Click image for larger version
Name:	Copy (2) of DSC_0111.JPG
catson4 is offline   Reply With Quote
Old 01-06-2008, 03:15 AM   #2
catson4's Avatar
1991 34' Limited
1st post with photos
As this is my first posting with photos I made some mistakes.
I have a piece of steel plate that is real close to fitting the curvature of the roof segment. I also will be modifying the roller to get a soother result.....
Start on the outside of the dents and work your way into the center...
Wish I had a lathe.
Claude
Old 01-06-2008, 05:07 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Very impressive. Do you have the piece of steel taped or otherwise attached to the outside when you roll the aluminum flat from the inside?
Old 01-06-2008, 05:25 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Very nice work. It certianly shows what can be accomplished with a little ingenuity and work. Good Luck.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 01-06-2008, 05:26 AM   #5
Silver Mist
LI Pets's Avatar
Riverhead , New York
With those results I wouldn't replace it.
If that can be polished you'll never see it
Old 01-06-2008, 10:41 AM   #6
GreatPumpkin's Avatar
Colville , Washington
Images: 70
I agree with Bob. Loks like you've done a good job with the repair. It appears that you've got hail damage? also. A new segment would stick out like a sore thumb there. You've rolled out most of the damage, and once it's polished up no-one will ever know.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 01-06-2008, 11:04 AM   #7
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Claude,
Bob's right on with his suggestions. It looks good already and with more finessing and the polish it will almost disappear.
Nice work. Very impressive.
Keep the photos coming as your work progresses.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 01-06-2008, 03:56 PM   #8
catson4's Avatar
1991 34' Limited
Thumbs up BIG C Clamp
Tommorrow I am going to weld up a large " C " clamp. I have to go buy one that has a 6" or 8" opening.
I will cut the ends off and weld them onto two 24" X 1 1/4" x .090 wall sq. tubing and these 2 pieces will form the "open" end of the clamp.
At the closed end of the clamp I will weld in two 8" long pieces of the same tubing , side by side, & this will give me an 8" distance between the long arms.
Next I am going to sand and plane a pair of 8" square wood forms that will lay on the top & bottom of the segment. These wood peices will conform to the roof contures. Then I will glue a piece of 1/4" steel plate to the flat side of each wood form. I may have to make numerous wood forms but I will see.
This will allow me to use the "C" clamp as a compresion press.
I believe this will give me a very smooth surface.
As I have the roof vent out, I can use the clamp by utilizing the vent opening.
After I get the clamp built and a trial run completed , I will post some more photos.
This is all a theory, so we shall see what we shall see.
Claude
TV Antenna Repair/ replacement/ leaks balrgn Audio, Video & TV 43 04-30-2017 05:05 PM
Bathroom faucet repair / replacement jesus mike Sinks, Showers & Toilets 7 06-08-2007 10:36 PM
1948 Floor Repair or Replacement???? oldtrucksrul Repairing/Replacing Floor &/or Frame 4 03-19-2007 08:52 PM
Heater replacement or repair. Deano69LY Furnaces, Heaters, Fireplaces & Air Conditioning 5 07-08-2006 11:43 PM
Shell-on, frame repair/floor replacement all at once?? pinkflamingoes Repairing/Replacing Floor &/or Frame 12 09-13-2004 05:11 PM
