07-17-2014, 10:31 AM
#81
1971 27' Overlander
Dickinson
, North Dakota
Thanks again Dave! I've been busy with the 'honey do' list lately so my trailer has been on the back burner or at least until after dark. Boy I see where they get this mistress moniker for ones trailer!
When I did the new water pump and plumbing under the sink I did re-create the drains there. I contemplated keeping it a bit simple there but I had to put in a drain for the fresh tank anyway so I just added the two additional valves. I also added a pump bypass valve that will allow me to re-fill the fresh tank when connected to city water. This will likely not be used much at all as we mostly boondock and if at best we may have a power connection. But I guess you never know!
Like you, I did away with all the ducting that was there and will replace with 4" aluminum dryer venting or something similar. I will run two ducts to the front by the door and especially since that space to the left of the furnace is kind of wasted anyway. I will then run two lines towards the back. One to the bedroom and one to the bathroom. I ended up raising my rear twin beds up about 4 inches to clear the side access hatch fully. This gives me more room over the wheel wells and I will try and tuck the lines there and then out of the way somewhere as they make there way to the rear.
The fun continues!!
07-17-2014, 09:06 PM
#82
1971 27' Overlander
Jackson
, Tennessee
Milestone day today: got the bathroom reinstalled and plumbed! Not ashamed to say I did the happy dance around the trailer after that last rivet went in! Bellypan back on, inner skins back in - something downright euphoric about those milestones…
Pics to come…
Next, I want to get the a/c on while my youngest son is home from school, then on to the cabinetry.
You guys may have already thought about this, but there is a good bit of discussion on here against the use of flexible vent of any type, mainly related to airflow, durability, etc. Possibly one of those overcautious/overbuilt issues? I went ahead and put in 4in rigid ducting, one fore, two aft, from the new furnace.
Anyway, hope y'all are having fun,
Alan
07-24-2014, 09:48 PM
#83
1971 31' Sovereign
Lake Minnetonka
Still waiting on these pics, suspense is killing me😜
07-25-2014, 03:23 AM
#84
1972 27' Overlander
Denver
, North Carolina
Hey Alan,
Sorry it's taken so long to catch up. That dang work thing gets in the way of everything! Sounds like you've done a hell of a lot of work and have the right to do the snoopy dance!
I got the skins in, plumbing up to the kitchen.
I've got a buddy who is ex hvac guy. Says "hey it's hot air, doesn't matter what you use". But like you I am coming to the realization that maybe just putting back the original is better. My duct looks to be 4x8, which I can't find at lowes. Where did you get yours, this weekend is family time so very little will be done but I'll get on it next week after work.
And, yeah.... Where's the pics???
Lucky Dave, Denver NC
07-27-2014, 07:51 PM
#85
1971 27' Overlander
Jackson
, Tennessee
Catching up
Bathroom reinstalled and plumbed. I used Flair-It fittings a la Uwe of Area 63 Productions (his old thread on a reno is still one of the best). Used a Hepvo drain on the tub, running back to the gray tank opening which will be under the bed.
Haven't decided what to do with the bathtub wall; I'm replacing the poorly designed sliding-door-cabinet thing that was the original wall. Finding a rigid replacement that looks good and is removable for future repairs is tough. Gluing panels to hardboard like a home bath isn't easily removed. I'm not crazy about the look of FRP and it's too floppy without backing. Any suggestions would be great!
Got the dump drain opening finished in the trunk with a little sliding cover that moves in a track made up of some aluminum scrap.
The furnace pic shows how I did the ducting. I did not want to move the intake piece on the outer skin, so I salvaged the old plenum by enlarging the right side opening, then attaching to a rectangle-to-double-round transition piece I rigged up from two smaller ones. This gives me the most space under the galley cabinet and also the proper amount of exit air surface area for this furnace (including the left-side duct).
Oh, and it feels good to have the ac install behind me, too.
Fun everywhere!
Alan
07-27-2014, 08:19 PM
#86
1976 27' Overlander
Tampa
Wow- nice work. Questions for you:
1. Did you epoxy coat your tub and bath counter? What did you use?
2. On the rear bumper/ trunk/ waste line area... Does that area fill up with water when it rains? How does it drain? Thats a cool sliding door.
Thanks!
Mic
07-28-2014, 09:42 PM
#87
1971 27' Overlander
Jackson
, Tennessee
Thanks!
Mic
Thanks, Mic. I treated myself to a break on the bath because I just didn't want to attempt that without good spray equipment/experience, and I needed to outsource a few things or never get finished. (Limited free time, working alone, outdoors, waahh, waahh, waahh…) Anyway, a bath refinisher guy used a commercial 2-part finish, and I really like the results. Having said that, I've seen some of the DIY products' results and they look great, too, especially with a little sanding and polishing.
My trunk area isn't sealed on the ends aft of the aluminum angle cross-piece yet, but I will eventually drill some holes in the trunk floor for drainage.
Alan
07-29-2014, 06:24 AM
#88
1972 27' Overlander
Denver
, North Carolina
So I've decided to replace my 4 year old suburban furnace with a wave 6 catalytic heater. I want to boondock a da furnace will run the battery down quickly. Comes in on Saturday an I ll take loads of pictures during the install process!
07-30-2014, 05:45 AM
#89
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Suburban heater
What size heater are you taking out, curious if you are getting rid of it. Been hunting for a NT34SP for my 31'.
07-30-2014, 07:46 PM
#91
1972 27' Overlander
Denver
, North Carolina
Cole, PM me. This is furnace is in excellent condition. I
Let's talk about it.
08-01-2014, 09:56 AM
#92
1971 27' Overlander
Dickinson
, North Dakota
Alan,
Your work looks awesome. My wife is giving me the rebuild the bathroom vibe so I'm currently just running with it until this fall and spending some time thinking about how I'm going to keep the tub and build a new vanity to have basically the same functionality. At the same time I still need the ability to hide plumbing and wiring behind it as well.
There are some weird layout issues with changing too much about the bathroom with the way the walls and the pocket door work there. You almost have to go back to some sort of pocket door if you want to keep walls in line, etc. The original pocket door was stupidly heavy for some reason or another. I want to try and find some new hardware and basically re-create it with a lot lighter construction and maybe some frosted acrylic sheets to let some light through.
I like your little sliding door idea for the dump valve. Mine originally had a hinged panel that latched and dropped out of the way. Did you use heavier material for the door itself?
Also, thankfully it has been warm enough where we have been camping to not have to worry about heat so that is another head scratcher for the time being. I like the argument for rigid ducting if it is buried like originally below the cabinets in the rear. The way I have it in my head to run the duct up and around my redesigned bed should make it easier to get to and 'mend' if necessary. In principle I don't like that thought but on the other hand I think it will provide more storage options under the beds.
Dave, I would like to hear your thoughts and reasoning on the catalytic heaters. I really like the idea of radiant heat but am not too sure on the air exchange issues. It seems somewhat counter intuitive to leave a window or vent open to run the heater. Are you going to run another unit in the back of the trailer as well?
I did sneak out and camp last weekend and going to do the same this weekend. I mounted my awning and so from the outside no-one would know it isn't quite done yet. I still haven't attached the belly pan under the black tank and bumper. I just can't seem to get a time that works for me or my buddy that has the metal break to bend those angles in there. Alan, did you bend your yourself or have someone do it?
Thanks!
Ryan
08-03-2014, 08:28 PM
#93
1971 27' Overlander
Jackson
, Tennessee
Ryan,
I originally wanted to rebuild the bath, but my plastic was in good shape - I only had to re-glass the area around the tub drain underneath - so I went with the old. Now if I could just figure out the tub/wall thing.
Agree with the bath door comments. I may just compensate the staggered walls with a wider frame facing offset on each wall (so the door frame trim is even across the opening even though the walls are not.) That gives me a bit longer bed on the curbside, which I need. Then, accordion door, or …?
The sliding trunk hatch is scrap 0.032 Alclad.
I look forward to seeing what you come up with on the furnace ducting; my double round ducts do kill storage space. Both rear ones will vent into bed room space; because of my tub plumbing, I couldn't get it to the bathroom. My wife wasn't too happy about that.
About the belly pan, the repaired lower frame metal that makes up the lower belly area on mine ended up not being exactly symmetrical, so I sweated over the measurements, but a local heating and air company cut and bent it to spec, and it worked out great.
Fun is the point,
Alan
08-04-2014, 06:18 PM
#94
1972 27' Overlander
Denver
, North Carolina
Well I'm hung up under the sink. Replaced that silly ass kitchen faucet with a new one. Pulled all the crap plumbing. Tonight was working on locating the flojet pump.
So I've been thinking about the location of the new heater and I am thinking of locating it street side in that cabinet that is kitty corner to the gaucho. I'm gonna remove the shelves and hook up a flexible 3 ' line to it along with legs so I can aim it towards the back of trailer if I want. I pondered installing it in the kitchen cabinet on the left when you come in the door, but I am not certain how effective it will be. I thought the doggone thing would heat the heck outta the front of the trailer but not so much in the rear. Thoughts?
Worked on her till the Mosquitos drove me inside. Florida humidity up here in North Carolina!
08-04-2014, 06:32 PM
#95
Hollis
, New Hampshire
Someday’59 did a cool job installing a cat heater under the kitchen sink, I'm not positive but as I remember it slid out and could swivel. Otherwise it was hidden in the cabinet.
08-05-2014, 05:56 AM
#96
1972 27' Overlander
Denver
, North Carolina
Hey Reinergirl!
The PO installed a new suburban under there and used the old case that was there you'd think he welded the dang thing to the frame! I'm gonna explore the other option on this one. Need to check my propane lines anyway.
10-10-2014, 07:10 PM
#97
1972 27' Overlander
Denver
, North Carolina
Been hung up on that dang work stuff.... Have my sink, toilet tub and water heater in. What I learned form all this was that Airstream - even 40 odd years ago used top of the line stuff. For example, if you need a new shower diverter a new one is roughly $110.00 from Moen. So I called Moen and learned they don't make our style any longer...but they do have a replacement cartridge. $27.00 plus $20.00 for the removal/install tool. I found both in one package for $24.00 on Amazon, score!! yay! So tomorrow ...theoretically I will complete the bath.
I've also decided to go with a peel and stick type floor from Lowe's. I believe like everything preparation and a good primer is key.. I'll update after things are a tad further along. I've installed a waterless P trap from Hepvco because the thought of cutting yet another hole in the floor for a Tub P trap was killing me. So tonight I rest a happy man. Will get some pics up soon.
Lucky Dave
10-10-2014, 08:23 PM
#98
1971 27' Overlander
Jackson
, Tennessee
Good find on the replacement cartridge; using the original faucet eliminates any difficulty mounting a new one (like I had). I am interested to see how you connect your new lines to it.
I had planned to use the waterless traps on all three of my drains, but I couldn't fit one from the bath sink to the existing vent/drain. The tub has one and so will the galley sink, and - yes! - no P-trap through the floor.
Congrats on your progress.
Alan
10-11-2014, 05:34 AM
#99
1972 27' Overlander
Denver
, North Carolina
Hey Alan,
Thank you! When I disassembled I left about 6" of copper on the hot, cold and supply feeds. My plan is to use sharkbites and connect the pex to them. The shower feed is 1/2" that goes through the shower wall. I have the shower connector and plan to use a sharkbite on it,pushing the sharkbite right up tight on the wall. The other side (in the tub) will have an escutcheon plate and some waterproof silicone, glue..not sure yet to hold it in there. Then I will drill two screw holes in the plate and screw it into a wood clock on the other side. Hopefully that will hold it. I don't have a pic of the original and I don't remember what it looks like.
On the water less, I only used one just before it goes to the black water drain. Were this application inside the house I would have one on every fixture.. But for the trailer, I don't think I need two. I still have one tiny leak on at the pump, I need to fix, but that outta be an easy one. Once that leak the shower diverter and then bath sink are hooked up,plumbing will be done and I won't know what to do with myself .
As an aside, where is Jackson Tenn?
Lucky Dave
10-11-2014, 01:50 PM
#100
1972 27' Overlander
Denver
, North Carolina
A pic of my diverter:
