Old 06-15-2015, 05:03 AM   #113
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I guess my main concern would be how tight the fit is; if the grip is really tight, would it be possible to rotate the fitting so that it can thread?
what do you think of this situation: http://www.airforums.com/forums/f444...ml#post1636968
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-15-2015, 08:18 PM   #114
1971 27' Overlander
Jackson , Tennessee
I see now what you mean - that would be a problem.
From looking at your setup, I think I would run it out the side instead of the rear, but use a Fernco coupling in place of the threaded connection; then you could use the grommet for a closed exit. Can you cut the hole through both existing frame pieces like Top did here: http://www.airforums.com/forums/f36/...-73643-11.html (last pic post #143)?
TennTex is offline   Reply With Quote
Old 06-15-2015, 09:07 PM   #115
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Yeah, I don't have to use that particular threaded fitting--I just like the idea of putting things like this together in a way that also lets you take them apart, should the need arise. (and it almost certainly will). But that one fitting isn't the only way to do it.
I can't go straight out the side without adding another extension piece to the existing one, and possibly lowering the tank a bit--in this area, the main frame channel is completely covered by the belly pan/banana wrap; in the bumper area, not an issue...and back there, you can cut into the main 5" frame rail and not be concerned about weakening it, because the frame isn't supporting anything back there.
I showed this to a co-worker today, who is also an rv-er, and understands "dump station" issues...he thought I should go back to the bumper, because of the ease of access...old knees and backs being the way they are. It would be an awkward reach to connect the slinky if I go straight out the side; much much easier with the bumper area connection. It would be easier to plumb, too...more room to work with. I'm starting to lean in that direction.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 06-16-2015, 07:52 PM   #116
1971 27' Overlander
Jackson , Tennessee
Easier to build, easier to use - I'd go for that. As long as you can keep the backside water- and critter-proof...
Have fun,
Alan
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
Brand new RVers went off deep end with 1968 Globetrotter rickyfish Member Introductions 8 01-19-2014 02:08 PM
looking for rear rear end molded plastic interior freerider 1974 Overlander 2 07-18-2012 07:39 AM
Sealing Rear Bumper area bwaysteve Bumpers & Bumper Storage 2 03-02-2010 12:16 PM
Off the deep end... blackboat Member Introductions 13 05-30-2006 06:39 AM
