Old 06-27-2013, 08:42 PM   #1
1967 26' Overlander
Springfield , Oregon
Scratches in my 1967 Airstream
My girl and I have recently purchased a 1967 Overlander International as our first foray into travel trailering.
I am in the process of my first polishing of a pretty rough Overlander. I have noticed after stripping the clear coat.and wool bonnet first cut a lot of profanities in the aluminium.
Is there any chance of sanding through the outer layer (if there is one)?
I guess that's my real question, does the aluminium go all the way through the skin.
I have sanded one spot with 500, 1000, 1500 and 2000 grit and everything came out fine, with the exception of I didn't sand deep enough to remove the middle finger scratched into my baby.
Any information would be helpful.
Will
Carrara68 is offline   Reply With Quote
Old 06-27-2013, 08:54 PM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Will
Your trailer is made of Alclad aluminum Alclad - Wikipedia, the free encyclopedia
And the surface layer can be sanded through so be careful.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
