Old 02-04-2007, 10:44 AM   #1
BB 55 Bubble's Avatar
1955 16' Bubble
Bend , Oregon
Rubber coating on galvanized steel
I received my new and improved wheel wells from the manufacturer a few weeks ago. I was advised to etch them with vinegar and clean with alcohol, and apply the coating of my choice. I used a rubberized under coating that I bought at Napa Auto Parts Part # 8400. First off it never did dry quite right; it is wet in some spots and dry in others. Second it is falling off in huge clumps 3 days after its application. Bug and tar remover seems to take it of. Any advice, should I prime, sand, try something different?
Beau
Ever notice an Airstream resembles a piggy bank
BB 55 Bubble is offline   Reply With Quote
Old 02-04-2007, 12:01 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Good question. Know from my Argosy end caps that epoxy paints will adhere after an etch preparation. Don't know that I'd want to sand the galvanizing. Was the NAPA product recommended by the manufacturer and did the label say it was for galvanized? Wonder if a truck detailer could spray on some bedliner?
5 meter Langford Nahanni
Old 02-04-2007, 12:32 PM   #3
Images: 59
Don't use vinegar. You need to remove the oil coating first, then use any of the commonly available primers or etchants for galvanized steel.
Maybe the sheetmetal guy who did your wheel wells remembers his grandpa using vinegar. Grandpa probably didn't have anything else. You do.
Vinegar and zinc form zinc acetate. Not a good substrate for paint. Water soluble salt.
I did use vinegar to age some copper garden lights. Works great on copper, not so good on zinc.
Old 02-04-2007, 01:20 PM   #4
1955 16' Bubble
Bend , Oregon
Lightbulb Rubber Dip It
OK it was a pain in the hinny to get any info on Sunday but alas I did prevail. So it turns out with a lot of scraping and Goof Off I did get the old coating off. I was informed by another sheet metal guy that indeed vinegar is BAD (wont work) instead a LIGHT!!! Sanding with a 50 grit paper and a through cleaning with denatured alcohol is the key. I picked up some Rustoleum primer and a product that I have used before called Dip It. It is a rubber coating that was designed to use as a protecting for tool handles. One can brush it on as a very thick paint with a foam brush. Works great as protection for the sheet metal and it also self levels with out running.
Old 02-04-2007, 04:09 PM   #5
Self-etching primer is the only way to go.
DuPont makes a good one.
Anon is offline   Reply With Quote
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
stainless steel wheel simulators Larry Brown General Motorhome Topics 11 11-26-2002 08:10 PM
Roof coating FrankR Roof 4 07-22-2002 01:56 PM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 07:50 AM
Airstream steel wheels davidz71 Wheels, Hubs & Bearings 0 05-21-2002 05:18 PM
