Old 03-13-2013, 02:38 PM   #1
1969 23' Safari
Athens , Georgia
Rub rail sealing
Ok, reinergirl helped me out on this, but I want to make sure I'm doing the right thing. I have mystery leaks. Does the rub rail need to be sealed all around? With vulkem?
Thanks!
sarasafari is offline   Reply With Quote
Old 03-13-2013, 05:22 PM   #2
1981 31' Excella II
New Market , Alabama
Yes but the hard part is getting all the old gunk off first.
Perry
Old 03-13-2013, 05:28 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Lets look at this
What needs to be sealed here is not the rub rail...it is the bottom of the walls which is
underneath the rub rail. Take that rail off....seal the wall and floor interface, then reinstall the rub rail and then seal the to edge. For what its worth.....
Old 03-14-2013, 06:29 AM   #4
1981 31' Excella II
I sealed under the rub rail where there are panel seams and on the top edge. Sealing the top edge should do the trick. I would not remove the rub rail to seal the edges of the panels unless you are already in there.
Perry
