Old 11-14-2019, 10:50 AM   #1
Pride&Joy's Avatar
2001 30' Limited
Terre Haute , Indiana
Rub Rail Resortation with Vinyl Pin Striping
Hi all! We have a 2001 30' Limited. Our rub rails had lost much of the silver coating. Decided to try vinyl pin striping to cover the rails as a cheaper fix. We ordered the following on line from 'MoProAuto.com":
1 x 1/2" x 150ft Professional Vinyl Solid Pin Striping Roll
(Select Vinyl Color Series: Avery Supercast A5701-M Silver Metallic)
We used a toothbrush, mild soap and rubbing alcohol to clean the rail before adhering the vinyl pin striping. The cost was just under $50 which leaves plenty of extra vinyl. I believe we could have used slightly wider striping but we are very happy with the results. Attached are before and after pics! Sorry about the pics, I could not rotate these! 2 before and 2 after pics.
Thought we'd share...
Stream on Airstream peeps!
Angie
ID:	356269   Click image for larger version
ID:	356282   Click image for larger version
Pride&Joy is offline   Reply With Quote
Install 1' Blue Rub Rail Vinyl zmaker Clearcoat, Exterior Paint & Trim 12 11-14-2019 07:12 PM
1975 Argosy 24í Rub Rail Vinyl Size? Cgp General Repair Forum 0 10-07-2019 09:10 AM
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 09:27 PM
Pin striping on a '73 Overlander Jerkyguy Clearcoat, Exterior Paint & Trim 9 03-02-2013 05:15 PM
Replacement exterior vinyl striping Padraic All Argosy Trailers 20 12-01-2006 01:59 PM
