Hi all! We have a 2001 30' Limited. Our rub rails had lost much of the silver coating. Decided to try vinyl pin striping to cover the rails as a cheaper fix. We ordered the following on line from 'MoProAuto.com":
1 x 1/2" x 150ft Professional Vinyl Solid Pin Striping Roll
(Select Vinyl Color Series: Avery Supercast A5701-M Silver Metallic)
We used a toothbrush, mild soap and rubbing alcohol to clean the rail before adhering the vinyl pin striping. The cost was just under $50 which leaves plenty of extra vinyl. I believe we could have used slightly wider striping but we are very happy with the results. Attached are before and after pics! Sorry about the pics, I could not rotate these! 2 before and 2 after pics.
Thought we'd share...
Stream on Airstream peeps!
Angie
