Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 10-18-2008, 06:09 PM   #1
Profile:  2006 19' International CCD
Philadelphia , Pennsylvania
Rub rail insert popping out a little in one spot...
hello all,
the rub rail insert's sticky black backing appears not be fully adhering in one 4"-6" segment.
are there any tricks to get this re-stuck?
thanks!
eric
ericwarren is offline   Reply With Quote
Old 10-18-2008, 06:53 PM   #2
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
you could use some spay stick adhesive to put it back in place.. 3m makes some good stuff
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-19-2008, 12:06 AM   #3
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Rub rail insert.
Hi, I would clean both surfaces and use a new piece of 3M two sided mounting/moulding tape on it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 10-19-2008, 07:50 AM   #4
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
[quote=ROBERTSUNRUS;628699] Hi, I would clean both surfaces and use a new piece of 3M two sided mounting/moulding tape on it.[/quote
Bob's got it.
Get as much of the old tape off as you can and clean both surfaces good, I think most have delt with the problem at some time. 3m does make some super sticky tape, get the industrial strength stuff.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
ROBERT CROSS is online now   Reply With Quote
Old 10-19-2008, 09:03 AM   #5
thanks all!
i'll head out to lowes today
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 17 11-23-2007 04:58 PM
Beltline/Rub Rail George Clearcoat, Exterior Paint & Trim 8 05-03-2006 12:21 PM
rub rail replacement atvmcg Clearcoat, Exterior Paint & Trim 3 01-18-2006 07:46 PM
Need help w/ rub rail RiskIt Clearcoat, Exterior Paint & Trim 3 07-24-2005 10:52 AM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 01:10 PM
