Old 10-24-2016, 11:21 AM   #1
1977 31' Excella 500
NEW HARTFORD , Connecticut
Roof pipe vent covers and fan vent covers
I read on VTS that the replacement pipe covers should be installed with rivers, mine are screwed ( two screws are frozen )
When I re-install them should I screw them or rivet.?
Also fan covers, seem to be functioning (winding up and down) but not looking so hot- does it make sense to replace? I will def be replacing fans.
Also, it's there an easier way to strip the caulk from them? I was using citrus strip but it was slow working..
stormbornSG is offline   Reply With Quote
Old 10-24-2016, 12:06 PM   #2
Sorry that pic was another question: it's on the front on the top of the curb any idea what it is?
Trying to post other pics now
Old 10-24-2016, 12:20 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
For what itís worth my Ď67 had plastic vent stack covers secured with rivets. The plastic had cracked around the mounting holes.
The í72 has cast metal vent pipe covers screwed in place. Stove vent is stamped aluminum with rivets.
Iíve replaced/repaired the plumbing vent stacks and used stainless steel screws and Tempro sealer with good results.
As far as I know if youíre replacing roof vents with the ubiquitous Fantastic Fans they come as an assembly. I saw one installation where they were riveted in place.
There are any number of sealers that have been smeared around vents. Iíve used Citri-Strip, mineral spirits, xylene, brake cleaner and a commercial silicone remover. Different sealers produce different results.
Can't help with the cover. Is it rusted? Probably not stock. Maybe home made stack cover?
Good Luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 11-09-2016, 05:27 AM   #4
Good Luck,
Tom.
Not sure where my "thanks" comment went. Upon further demo, I've found all the vents full of bee and wasp nests. Also the cranks don't work or dont work well. IF fantastic fans are complete assembly, I'll just do that. I guess I'll have to do with while the interior skins are stripped?
Did you relocate the vent stacks at all?
Orig.Vent Pipe Covers - Still Available? Creampuff Roof Vents, Skylights & Fans 2 07-24-2014 05:50 PM
Roof Fan Vent Covers (See pic) Akronguy General Repair Forum 1 06-12-2014 04:57 PM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
Pipe vent covers storing water... should I worry? ronstory Roof 12 10-01-2008 01:38 AM
Vent pipe covers.. ??? Happycampers Roof Vents, Skylights & Fans 5 09-08-2004 11:09 AM
