Old 09-14-2014, 10:11 AM   #1
1976 25' Tradewind
Oswego , New York
Roof dents
As I tackle the dents in the roof, I will take photos to share. My plan is to make templates of the areas to be worked, draw a solid model in the program I use (Cobalt)and cnc mill out wood bucks to push behind the dent via a 2x4 held by a cleat screwed to the floor. If a exterior mold is needed I'll make that too.
I'm going to experiment with shrinking the creases using a test piece in my shop. Does anyone have experience trying something similar to this?
Mike
micagadams is offline   Reply With Quote
Old 09-14-2014, 11:08 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I hate to be blunt here, but you are going to spend a whole lot of time with minimal results. Replacement would be my first choice, but in loo of that, and if you are determined to re-contour, remove the panels and use a quality English Wheel with alot of annealing to re-form the panels. I do not think that the results would outweigh the expense of the English Wheel. You could also make a 13 panel segmented cap.
How much aluminum forming skills do you currently have.
I have been doing aluminum work for approx 40 years and I would replace the panels with new or make the segmented panels.
Old 09-14-2014, 06:18 PM   #3
1976 25' Tradewind
Oswego , New York
Thank you for your reply. I agree with you and respect your experience, I'm delaying this work until a later day. We popped out some easy ones and made it look a little better, worked some areas with a soft rubber mallet, and called it a day.
I have an english wheel I used to make corners on a copper range hood, I thought it was used for expanding not shrinking.
Old 09-14-2014, 07:37 PM   #4
Aerowood's Avatar
Arvada , Colorado
You are correct with the English wheel stretching. The issue is that the aluminum is going to stretch as it is reformed, especially the areas that are kinda folded. So you would have to stretch them to straighten them and then shrink the aluminum back down. The metal will also work harden as it is re formed which would then require annealing to continue.
Old 09-14-2014, 07:57 PM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Thats one cool/beautiful looking range hood!
mayco is offline   Reply With Quote
Old 09-14-2014, 08:13 PM   #6
1981 31' Excella II
New Market , Alabama
Really Cool Steampunk range hood.
I have to agree with Aerowood on either replacing them or taking them off to work out the dents. If you are really good with the English wheel you could start from scratch and make new panels or do the orange peal end caps. I expect you could pull off the orange peal strips. I think the old panels will take more work than starting over.
Perry
Old 09-16-2014, 03:57 PM   #7
1976 25' Tradewind
Oswego , New York
After thinking about it, unless you replace the bent panels, any english wheel work or other fixing would rapidly make it difficult to reinstall the panel. At least the panel is constrained while in the roof. I noticed some references to a roller being available, is this for dents?
I have metal spinning rollers that could be modified, might this be similar to Aerowoods roller?
Mike
Old 09-16-2014, 06:58 PM   #8
1981 31' Excella II
You can always match drill if the holes don't line up. Putting washers on the back is also a good idea in case the hole is not perfect or intersects another hole. You are going to have to anneal the heck out of the panels to get the creases out.
Perry
Old 09-16-2014, 07:34 PM   #9
1976 25' Tradewind
Oswego , New York
I'm pretty much determined to do them in place, do I use the burn off the sooty acetylene method to anneal? Here's with popping and some mallet work.
Name:	before and after.jpg
Old 09-16-2014, 07:52 PM   #10
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I can only say- wow. Your mallet work did quite a bit. All you can do is try and see if the result is acceptable. If so great, if not get the panels replaced.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 09-16-2014, 09:00 PM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I would say that is at least a 90% improvement. Nice mallet work!
Dan
Old 09-16-2014, 09:06 PM   #12
2006 25' Safari
Images: 8
micagadams, you could name her the hammered wonder or alumamallatata!
Old 09-16-2014, 09:25 PM   #13
reinergirl's Avatar
Hollis , New Hampshire
Holy moley, I gotta say that looks great... If you can do that much with a mallet, I'd try a roller and call it quits.... They all have some damage!
reinergirl is offline   Reply With Quote
Old 09-17-2014, 01:44 AM   #14
1976 25' Tradewind
Oswego , New York
mallet work
Thanks for the compliments. I will post some more pictures when we have done what we could. This is some other mallet work we do.
Roof dents appearing Silverflames Roof 16 07-09-2013 07:21 AM
63 Safari Roof Dents hockeyrink Ribs, Skins & Rivets 4 02-11-2008 06:21 AM
Dry ice and dents.... Silver Bullet Ribs, Skins & Rivets 19 11-13-2003 11:41 PM
Removing rear skin due to dents IPM Ribs, Skins & Rivets 11 09-02-2003 10:11 AM
Dents Jenturnr Ribs, Skins & Rivets 1 03-11-2003 06:58 PM
