Old 05-24-2015, 09:28 PM   #1
1970 27' Overlander
Houston , Texas
Replacing radio antenna weather stripping on 1970 Overlander
Hi guys!
I am trying to replace the corroded weatherstripping around my 1970 Overlander's radio antenna. I haven't found any replacement parts online, and I'm wondering if any of you know where I might look? Also, I've tried unscrewing the bolts on the antenna to remove the corroded rubber piece, but it seems there are bolts holding me back on the inside of the skin. Is this the case? I just want to make sure before I remove some of the inner skin. Thanks for any and all help!
Best,
Andre
aboudre1 is offline   Reply With Quote
Old 05-24-2015, 09:54 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Yes, there are nuts on the backside that you will have to get to by removing some inner skin. You can find replacement radio antenna mounts on Amazon, or go to an amateur radio shop (not Radio Shack). They should have some upgraded mounts and a selection of various length antennas. I replaced mine on my '72 Trade Wind
arktos55343 is offline   Reply With Quote
Old 05-24-2015, 11:00 PM   #3
1974 Argosy 20
Kooskia , Idaho
Originally Posted by aboudre1 View Post
Hi guys!
Best,
Andre
Depending on where the antenna is vs. the inside and where the cable goes, you might consider grinding off the bolt heads from the outside, pushing the remainder into the cavity and replacing the bolts with riv nuts which are threaded inserts that go into aluminum like giant pop rivets and give you a threaded hole to put the new bolts into from the outside.
The issue would be where the cable goes through the wall to the radio and how you would fish the new one through replacing the old one. What I am assuming is that you need to replace the entire antenna, not just the gasket.
replacing radio antenna on 71 Lumatic Audio, Video & TV 17 07-06-2009 07:31 PM
weather stripping Londoner Windows, Doors, Locks & Vents 7 07-13-2008 08:03 PM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 06:10 PM
Need new weather stripping kit lizh Windows & Screens 8 08-30-2002 07:49 PM
Window Screen Weather Stripping ??? niftypkg Windows & Screens 0 06-03-2002 06:28 PM
