Old 07-31-2014, 09:17 AM   #1
Replacing front skylight
I have a semi-recently purchased AS that has a missing front skylight. The dimensions are 24 "x 14". I have already purchased the only replacement part available for it off of VTS. But now I am left to make it work using the mounting pieces from one of the standard 14"x14" vents (which I replaced with fantastic fans). So here is the actual question: Can I rivet the hinged telescoping arms directly to the new plastic cover or do I need to try and fab a piece of metal to rivet too? Click image for larger version
Name:	ImageUploadedByAirstream Forums1406816172.737979.jpg
ID:	217922Click image for larger version
Name:	ImageUploadedByAirstream Forums1406816212.329807.jpg
Tradewinder is offline   Reply With Quote
Old 07-31-2014, 09:43 AM   #2
Originally Posted by Tradewinder View Post
I have a semi-recently purchased AS that has a missing front skylight. The dimensions are 24 "x 14". I have already purchased the only replacement part available for it off of VTS. But now I am left to make it work using the mounting pieces from one of the standard 14"x14" vents (which I replaced with fantastic fans). So here is the actual question: Can I rivet the hinged telescoping arms directly to the new plastic cover or do I need to try and fab a piece of metal to rivet too? Attachment 217922Attachment 217923
That part is called an "Astrodome".
It is also available in milk white and solar gray, both of which have a "thermal barriers.
The operators are riveted to the cover. Instructions and the rivets should have come with the cover.
Old 07-31-2014, 10:05 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
http://www.airforums.com/forums/f456...stic+fan+crack
Considering all the trouble folks are having with plastic components on their roofs, i think if i were you i would try to fabricate something out of aluminum to back up the plastic where the fasteners will be located.
mayco is offline   Reply With Quote
Old 07-31-2014, 11:03 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
So, not clear about your intentions. Are you wanting a SKYLIGHT or a vented opening?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-31-2014, 12:13 PM   #5
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Here's what I did as the replacement skylight "had issues"
like yours.
Pricy? yes but it will last forever and I get easy access to
the roof.
Check my earlier post as since I got drop box my photos
are "all over the shop"
G'luck
Del
PS: photos taken before sealing perimeter...and I made
a little ladder to climb out.
Name:	2012-09-29 12.30.16.jpg
ID:	217933   Click image for larger version
Name:	2012-09-29 15.43.07.jpg
Del Gurney is offline   Reply With Quote
Old 10-16-2014, 09:29 PM   #6
2015 27' FB International
Chapel Hill , North Carolina
Del - Your hinged skylight is exactly the sort of access port to the roof that I've been looking for to replace the 20 in square skylight on my International. What size is that? I'm installing solar panels on each side of my sky light and would like easy access to the roof and solar panel tilt bars.
RichardW is offline   Reply With Quote
1969 Overlander replacing air conditioner with skylight lionheart Roof Vents, Skylights & Fans 21 11-12-2015 05:52 PM
How to fix skylight/front window... vander.karli Windows & Screens 3 05-02-2014 03:08 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
Double seals on skylight? TomW Roof Vents, Skylights & Fans 1 03-01-2004 09:44 AM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 10:16 AM
