Old 09-02-2016, 10:29 AM   #29
2007 22' International CCD
Also got mine a day or two ago. Looks beautiful!
Now to figure out exactly where to mount it...
KE4GNK/AE
Old 09-02-2016, 10:45 AM   #30
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Hey Shiny, What's the Bronze composition? I did a lookup and didn't know that there were so many formulations, Aluminum Bronze, Tin Bronze, Silicon Bronze. Sheesh! The reason I ask is to understand how much I need to worry about corrosion if I mount this to the coach.
http://www.pemnet.com/design_info/galvanic-corrosion/
SuperTrouper is offline   Reply With Quote
Old 09-03-2016, 09:01 AM   #31
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Got my pair two days ago. The first one will be mounted in the Classic on the wall beside the stove between the custom stainless steel side splash and the exhaust fan. Really like the look and finish. A job well done.
Old 09-04-2016, 09:23 PM   #32
1959 24' Tradewind
Heber , Utah
They will all cause corrosion if in direct contact with the aluminum. If mounting to your trailer then I would suggest coating the rear with a few coats urethane clear coat from your auto store. I use a mixture of materials primarily silicone bronze but we do mix this with C23000 for color. so essentially you will have about 85 to 90% copper then some zinc silica trace amounts of iron lead and manganese.
shinytincans is offline   Reply With Quote
Old 09-05-2016, 11:38 AM   #33
Thanks Much! I have some time to decide where to mount it. It's beautiful! It's the "s" that sealed the deal for me. I like the art deco style.
Old 09-08-2016, 11:58 AM   #34
switz's Avatar
2014 31' Classic
Images: 8
Have installed our first one in our 2014 31' Classic above the magnetic stainless steel stove side splash.
1967, 24' Streamline Countess, more rare than an airstream! eBay Watch Airstreams on eBay 0 10-13-2013 09:00 AM
Slept in more than 1 Airstream? Leprechauna On The Road... 22 08-05-2013 10:10 AM
Iconic American Products for Airstreams danlehosky Airstream Lifestyle 89 02-18-2013 11:27 AM
1967 STREAMLINE COUNTESS CAMPER. 24'. More rare than an airstream! eBay Watch Airstreams on eBay 0 09-16-2012 07:50 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 07:56 AM
