Old 03-24-2005, 09:44 PM   #1
New owner of 16ccd/RUST question!!
I just purchased a new 16 ft ccd 2004 in the state of Ohio! I live in Ca, needless to say it was a
long trip, 2700 miles.
I did get the brakes, and weight distribution/sway unit. It pulled like a dream.
I have a 2004 chev 1/2 5.7 V-8 3.73
After getting it home and cleaning the unit I notice it had pitted rust on all the
chrome around the rear lights, just above the license holder (that chrome thats above the light, and on the side the chrome insert around the water inlet on the left side. I tried wax, but its from the inside out, no luck. I can't believe that it rust that badly, having never left the lot. I guess this would be covered by
warrenty, but I will have to take it to a dealer here in Ca. Would that be a problem? The reason I didn't purchase one in my home state is that I couldent find a 2004 in my area, and it did have a good discount because of the fact that it was over a year old.
imagine is offline   Reply With Quote
Old 03-24-2005, 10:28 PM   #2
Big Dee's Avatar
2004 30' Classic
San Jose , California
Images: 24
Congratulations! Isn't it sweet to be the owner of a new Airstream? Toscano RV in Los Banos is for sure your best bet. They have a great service dept and will take good care of your coach.
Consider coming to the NorCal Forum Rally at Casini Ranch in two weekends. Would love to see your new CCD if you could make it. Think about it!
Happy Trails!
"It's the journey."
NorCal Fall Rally, Jackson Rancheria, October 7-9 2011 Click here for more info
Come rally with us.
Big Dee is offline   Reply With Quote
Old 03-25-2005, 05:55 AM   #3
2003 25' Safari
Eden Prairie , Minnesota
The license plate frame and light housing on my Safari rusted immediately also. It was replaced under warranty. However, I believe the part is made out of poor materials and the rust will soon reappear. You may end up shopping for a different part. I think my water inlet (water tank fill) is made of plastic, so no rust. These parts are easy to replace.
I also had corrosion on many other parts. see this thread for photos and descriptions:
http://www.airforums.com/forum...ead.php?t=8654
Keep your unit away from salt - I think the salt air from Tampa Florida (where I purchased my unit new) is what caused my unit to corrode.
Dan
dmac is offline   Reply With Quote
Old 03-25-2005, 07:57 AM   #4
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
"Signalstat 435". If that's the name on your license plate holder, you can figure on it rusting. That is the only item that ever rusted on th '99 (aside from the normal surface rust from hitch components which is kept in check with WD-40) and darned if that same item isn't on the '05.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 03-25-2005, 08:39 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
So far, ours has not rusted (yet). I have Walbernized it every time I Walberinize the rest of the coach. That may have bought me some time, I don't know. As of now though no rust. The coach was outside all of last year while in use and in storage. This past winter is the first winter it's been inside stored.
Now I see you bought a 2004. Knowing that the 2005s have been out for about a year now, that would mean that if this is a new coach, that it could have been sitting outside for all that time and if not Walbernized, it too could have started the rusting process...... just a thought.
Old 03-25-2005, 06:50 PM   #6
frozen chosen's Avatar
We pulled our 16 up the Alcan to Anchorage, so can relate. Be sure to check out past posts on 2004 CCD's and to inspect the shelving screws/anchors, antennae wiring connections to the 2 coax outlets for continuity, shower door fittings, and such. Also there are some good ideas for the noisy refer fan, closets, tv's, and other 16ish stuff.
frozen chosen is offline   Reply With Quote
New Owner "ALMOST" JLD 1974 - 1979 Sovereign 2 01-01-2007 06:57 AM
another Caravel owner davidw 1966-68 Caravel 46 02-03-2005 06:53 PM
MH Owner Listing Idea ViewRVs Airstream Motorhome Forums 46 06-26-2004 04:33 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
