Old 03-31-2013, 11:47 AM   #1
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
Need Seam Sealing Recommendations
We have a few seams we suspect are leaking on our '74 Sovereign and would like some advice from those of you with experience sealing seams.
What products do you use and any other recommendations you may have for the best results?
Also, on the second pic, what is the black object next to the polarity light?
Name:	Airstream Seam 001.JPG
ID:	182182   Click image for larger version
Name:	Airstream Seam 002.JPG
Dave
Okiestreamer is offline   Reply With Quote
Old 03-31-2013, 11:56 AM   #2
r carl's Avatar
Lin , Ne
I put tape on each side of the crack and rubbed-pushed gray Vulkem into the seam, worked perfect.
Old 03-31-2013, 01:03 PM   #3
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Apply the blue tape on each side of the seam leaving about 1/8 inch on each side. Use the trempro/vulkem to seal the seam. Cut the tip at about 20 degree angle. Push the vulkem/trempro in. Use the tool to further push it in and smooth it out.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
