09-05-2012, 09:05 AM
1976 31' Sovereign
Houston
Need Replacement Windows
I am restoring a '76 Airstream Sovereign, 31' long. I need to replace 3 window frames (31" wide) on the curbside. I would prefer used frames. If they are not available I would prefer used windows.
Can you recommend some sources?
Thanks, Eric
09-05-2012, 09:18 AM
1960 26' Overlander
1963 24' Tradewind
El Paso
Thanks, Eric
I'd try Andy@Inland RV or Out of Doors mart.
09-05-2012, 09:33 AM
Ottawa
, Ontario
Howdy Eric, and welcome to Airforums.com! Say, we share the last name, and I have a brother with your given name. Does that make us family!?
Another place to try might be Colaw's RV Salvage. As their name implies, they are a wrecker of all brands of trailers, so might have them in stock.
Stay Calm. Be Brave. Wait for the Signs.
09-05-2012, 09:40 AM
Corona
Thanks, Eric
A window "frame" is riveted to the shell.
The metal part around the glass is called a "sash"
An opening window is a sash and glass.
What is it you need?
09-18-2012, 01:57 AM
1975 31' Sovereign
cary
, North Carolina
Im working with a 1975 31' , and need the left side vista window and frame...just cant find the suckers.
09-18-2012, 04:47 AM
Well Preserved
Colfax
, North Carolina
Have you tried the second place mentioned in post #2?
Intelligence is learning from your mistakes. Wisdom is learning from others' mistakes.
02-07-2013, 02:54 PM
WBCCI 8562
1975 31' Sovereign
Pima
I saw a article in the latest Escapes magazine that there is a place in Phoenix
the rebuilds RV windows, alas don't have the mag. Anyone hear of them, and do they
do bubbly Airstream Windows. Every side window in my unit has bubbled, Arizona heat
I suspect
 Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
02-07-2013, 03:24 PM
Corona
I suspect
There is nothing wrong with your double pane opening windows.
What the bubbles are from, is a film that is on the inside of the outside glass.
The windows can be taken apart, remove the film, reassemble the windows and then reinstall them.
Most owners have chosen to do that repair themselves.
The stack and vista view windows is another story. Some people break away the interior glass, then remove the film, and then have a beer.
We recommend the beer, but not the breaking of the glass.
02-07-2013, 04:29 PM
1967 22' Safari
MILAN
Used Parts
Thanks, Eric
Eric, Try RVRevive.com for the phone number and ask for Ryan. They are located in Waterloo, Iowa and stock parts removed from damaged trailers. Tell him I refered you if you like. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
02-07-2013, 04:42 PM
Ottawa
, Ontario
I am going to guess that since he first posted this question back in early September last year, he found what he needed to know...
| Thread Tools |
| Display Modes |
