Where can I get a nameplate for my 1975 Airstream? I like the ones Vintage has....but I hate to pay $35 each plus shipping for them. Any place else to get a reproduction, etc? Haven't seen any on ebay.
__________________ 1975 Argosy-Airstream 24 Center Twin.
1980 Apache Royal Hard-Side Popup.
1996 Buick Roadmaster Wagon 5.7L V8, AT/OD, factory tow package, plus coil over shocks, class 3 hitch, brake box, trans cooler, and this and that.
Airstream used individual raised letters rather than nameplates in 1975. Each letter had 2 attached mounting screws. The nameplates you mention on VTS are for 1960's models.
The Airstream online store has nameplate decals for $16.95 each. They would not be the same as original for a '75 but would serve the ID purpose since yours is an Argosy.
__________________ Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Reason: correction
Rog0525 is correct about raised letters yes, painted nameplates no. The were not attached with "mounting screws but pins cast into the back of the letters. They were installed before the inside end caps. The pins go through the skin and are secured with a washer that grabs the pin and gobs of white goopy stuff. Are your letters missing? Incidentally you can rearrange AIRSTREAM to spell I ARE SMART.
Pay no attention to the man behind the curtain- WoZ
I referred to the pins (aka stems) as screws because a hex grab nut threads on to them. Those stems break very easily. My guess would be that someone broke the stems off the Argosy letters when they removed them to paint the end caps, then couldn't reattach the letters.
