Old 03-05-2019, 10:47 PM   #1
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
Name that thingamajig!!!
What is the strange tube like thingamabobber on the outside corner of my airstream?
badpaddler is offline   Reply With Quote
Old 03-05-2019, 11:15 PM   #2
SlvrTwinkie's Avatar
1976 29' Ambassador
Logansport , Indiana
I'm not positive but my guess is that is your antenna mast. I do know older trailers from the 60's and prior had those. My dad's 25' '72 Lark MH has one too, just doesn't look quite like yours though.
SlvrTwinkie is offline   Reply With Quote
Old 03-05-2019, 11:15 PM   #3
1980 24' Caravelle
vallejo , California
that is part of the tv antenna. on the inside of your trailer is/was a small hand-crank that turns gears in the small box at the bottom of the shaft. this rotates the antenna. kurt
ke6gkv is offline   Reply With Quote
Old 03-06-2019, 07:38 AM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
It's a “Braund Interceptor” made in Battle Creek, Michigan
That is a difficult part to find. It is an exclusive to 1967/68 antenna rotor. A rotor directional antenna is generally superior to omni-directional.
Yours is installed in the correct area, street-side front, but in an unusual configuration. It's most commonly installed with the gearbox between the two bushed brackets. I'd guess perhaps a California or Dealer install. The box at the bottom, I've never seen. Your trailer is pre-wired with 300 ohm TV flatwire, perhaps that's where it enters the cabin.
The rotor device can be restored. It's very simple inside the pot-cast aluminum housing. The Nylon bushings are easy to find. They're made by Heyco.
The corresponding interior cabin gearbox has a N-S-E-W pointer and is about 5”D, made from brown Bakelite. The entire gizmo is quite functional with today's Over The Air TV reception. Originally, a telescoping mast that had a folding VHF antenna fit into the tube that remains on yours. Today, you'd choose to mount a UHF antenna, and perhaps a YAGI WIFI.
It is a desirable, historical and functional part. Most of them were junked during the pre-digital and cable TV era, then patched over.
DEFINITELY A KEEPER!
Name:	antenna rotor.jpg
ID:	335054   Click image for larger version
Name:	dec 2011 nikon dump 408.jpg
ID:	335056   Click image for larger version
Name:	dec 2011 nikon dump 407.jpg
ALUMINUMINUM is offline   Reply With Quote
Old 03-06-2019, 08:34 AM   #5
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
Thanks! That is what I thought it was. The 67 has bracket and a hole I had to patch from one. This one I will just rebuild. Not even really concerned if it is functional or not.
Seth
Old 03-06-2019, 04:26 PM   #6
Central , Mississippi
Our '63 and '61 have them in slightly different configurations. The old antennas work great on digital tvs
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-07-2019, 09:09 PM   #7
1967 22' Safari
1958 18' "Footer"
North Pole , Alaska
That is what the setup would have looked like on my 67. Not sure if we will have a TV in there or not, but I am definitely not planning on removing it now.
Name? Does my Airstream need a name? xo1rider Off Topic Forum 51 12-21-2011 01:25 PM
To Name or Not To Name...that is my question! L&R Our Community 26 07-14-2009 09:40 PM
Motorhome club name ViewRVs Airstream Motorhome Forums 9 06-09-2009 07:18 PM
How to Pronounce Wally Byam's Last Name ?? hex WBCCI Rallies & Events 4 09-17-2002 09:34 AM
Pet name for trailer davidz71 Our Community 10 06-19-2002 06:38 PM
