01-01-2014, 07:42 AM
Registered User
2016 28' International
Birmingham
, Alabama
Minor scratches in Clearcoat
I scraped some bushes yesterday and put some scratches in the side of my 2014 FC?
The scratches do not appear to go through the Clearcoat.
I waxed the scratches with auto wax and some but not all came out.
What else could I use to get the scratches out without damaging the Clearcoat ?
01-01-2014, 08:07 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You may not be able to get them completely out if you can feel them with your fingernail...but I used these 3M products with good results after we encountered a wayward bush.
Good luck...
"You don't know where you've been until you leave, enjoy life" RLC
01-01-2014, 08:09 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Wax will not remove scratches. You will need a compound to do it. Compounds have some abrasive which is going to help remove light scratches. You may see it marketed as a cleaner compound but in any case buff it out with the compound and then wax to protect the surface after. Extreme scratches may need to be machine buffed but most light ones and small areas can be done by hand. Check around there are lots of products available.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
01-01-2014, 08:55 AM
2007 28' International CCD
Springfield
, Missouri
For minor scratches 3M Finesse is a mild compound that is designed for this purpose.Best used with a buffer.If you have no buffing experience any auto detail shop can do this for you in 10-15 mins.
Do not use old fashioned rubbing compound as it is way too abrasive for clearcoat and the results will not please you.
01-01-2014, 09:11 AM
Naples
Try some of this: Paint Glaze, 16 Ounces - Griot's Garage
My service van has a full-body vinyl wrap, and I also brushed across some bushes. While the scratched vinyl was not glaring, it was bothering me. I am a great fan of Griot's products and have been using them almost since they started, over 25 years ago.
This product performed exactly as stated. The scratches did not go away, but were almost invisible after use.
Try it…..you'll like it!
lewster
03-12-2014, 08:50 PM
2013 30' Classic
Greenwood
, Mississippi
Griot's garage products are available at the Advance Auto Parts store here.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
03-12-2014, 09:42 PM
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell
, Lousy-Anna
nu-finish!!!
06-08-2019, 04:25 PM
2018 27' International
carbondale
Just wondering if anyone has any new ideas/products for light scratches in clear coat. Mine are from bushes. Thanks
06-08-2019, 04:35 PM
2012 Avenue Coach
Corpus Christi
See above^^^^.
06-08-2019, 08:36 PM
2016 27' International
Sherwood Park
, Alberta
I have used Meguiars Ultimate Compound and a DA polisher with excellent results on my AS. A compound is what you are going to need for scratches, not a wax. But remember to go with a fine compound. The clear coat on Airstreams is not the same as the clear coat on your car, it is much softer. If you go too heavy or too much, you will blow through the clearcoat resulting in a very bad day.
https://www.amazon.ca/Meguiars-G1721.../dp/B001O7PNNM
06-09-2019, 05:36 AM
2019 30' International
Pennsylvania
, Pennsylvania
I've used Scratch Out with success on fine scratches. Looks like Meguiars makes ScratchX 2.0.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
06-09-2019, 07:40 AM
2012 Avenue Coach
Corpus Christi
Excellent cautionary advice. Go light. You can always redo the area if you need to.
06-09-2019, 07:45 AM
Tampa
I had a scratch that was pretty bad. I started with Nu-Finish and wasn't making much progress. So I switched to Simichrome. I had it for polishing metal at home. It's like toothpaste (another idea). Put a tiny dab on a clean cotton cloth and work. No power tools. I did a little at a time, I probably spent 4 hours total. Pull up a chair. Now, I can't find the scratch.
Since you use it sparingly, a small tube lasts forever.
06-09-2019, 08:00 AM
2012 Avenue Coach
Corpus Christi
Another consideration is the scratch does not need to be completely removed. So long as you get most of the scratch out, it will probably not be noticeable to others. And probably not to you if you didn't know where to look.
06-10-2019, 05:49 PM
carbondale
Thanks guys, I like the idea of trying the semichrome. Will let you know.
06-11-2019, 10:56 AM
Sherwood Park
, Alberta
Simichrome is really designed for bare metal, brass, bronze, chromium, aluminum and other similar metals. I would be hesitant in using it on a clear coat finish like that on the AS.
