Old 10-31-2014, 02:26 PM   #1
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Minor dent in center roof panel
I don't know how this happened... it was there when we bought the trailer (2006 19' Bambi Safari). It looks like someone leaned on the roof panel a bit too much while doing something to the roof. It is hard to photograph the dent, but I have attached the best shot I've got. There doesn't appear to be any creases in the panel.... it is just pushed in.
So what would be the best way to remove the dent? I plan to have it done, but want some idea of the best method before talking to the dealer. I have heard that a suction cup might work...anyone with experience with this technique? I could have the center panel replaced for $2k, but that seems like overkill.
Thanks in advance for any input.
George
Tucson
P.S. I see my attached photo is not attached. Please email me if you would like to see the dent pic. gmhatfield100atgmail.com
ghatfield is offline   Reply With Quote
Old 10-31-2014, 02:35 PM   #2
ghatfield's Avatar
2006 19' Safari SE
Minor dent in center roof panel pic
Here is the image I tried to post with my original message.
George
Name:	dent in roof sm.jpg
Old 10-31-2014, 02:56 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
See if you can find someone with a vacuum slide hammer.
2004 Excursion 4x4
Old 10-31-2014, 02:57 PM   #4
2007 27' Safari FB SE
Spokane , Washington
George,
The end cap is expensive to replace. Try the suction cup deal cause thats a big enough dent that you can actually pull out. If that doesn't work try this.
Post your outcome.
shaggy1970AS is offline   Reply With Quote
Old 10-31-2014, 04:21 PM   #5
George
That metal is soft, but still expands with heat.
I would wait until fall of 2015 before you try to remove it.
In the mean time, exposure enough times to a hot sun, may make that dent simply "pop out". And if it doesn't, you haven't spent a dime.
Your hot sun season is over for this year, so just be patient. Enjoy
Old 10-31-2014, 05:20 PM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I think that will come out easily with a suction cup. I found so thing very similar on our
trailer - after I bought it used! It wasn't visible from the ground but I still wanted to try to fix it.
A large suction cup for auto work (Try Harbor Freight?) should deal with it easily. Mine wasn't the slide hammer type, it just had a handle for pulling and a valve to release the vacuum.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-31-2014, 05:54 PM   #7
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I have same one on top, new saw when I purchased, discovered when I got home and looked down on driveway and saw it. I also have slight tennis ball dent. The big issue is owner #1 tried to remove sap with brillo, my AS has character!
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 10-31-2014, 06:05 PM   #8
gdanderson's Avatar
1967 22' Safari
Monona , Wisconsin
Here is an older thread you might find useful. I was able to accomplish just what you are needing.
http://www.airforums.com/forums/f381...al-126694.html
Greg Anderson
Wisconsin
gdanderson is offline   Reply With Quote
Old 10-31-2014, 07:34 PM   #9
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Install a solar panel over it.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-01-2014, 12:40 PM   #10
1993 30' Excella
Kaplan , Louisiana
If you contact P & S Trailer in Helena, Ohio and talk to Kevin, ask him about the best way to remove that dent. I had a creased rear center panel on my 30' Airstream and he used a devise and neatly removed that long crease. It looked OK but he advised that I should change this panel as the clear coat might show up the effects. Just a try but well worth it
jmland is offline   Reply With Quote
Old 11-01-2014, 04:05 PM   #11
1967 17' Caravel
Centennial (Denver) , Colorado
Take it to the best automotive dent clinic you can find in your area, they're going to do a much better suction cup attempt than you will. johnskalet
jskalet is offline   Reply With Quote
Falling tree = roof dent...how bad?! mel1501 Roof 11 07-05-2013 01:34 PM
Another Roof Dent Question airtime Roof 6 09-15-2010 06:09 PM
Temp repair to hole from dent in roof. Mrcrowley Roof 1 09-12-2010 04:38 AM
Small dent? New panel? sumsmug Ribs, Skins & Rivets 15 09-19-2007 01:06 PM
Minor Rust/Paint Missing on Galvanized Parts heyskipper Clearcoat, Exterior Paint & Trim 8 03-04-2003 08:35 AM
