Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 08-20-2013, 08:54 PM   #1
2002 34' Classic S/O
Irvine , California
Images: 11
Maintaining a polished exterior
I'm looking to buy a 1996 AS that was polished 6-7 years ago. Generally it looks good, but it is cloudy. Should it be re-polished? Or is there some other way to clean it up? If I do have it re-polished, what life span can I expect, and what maintenance should I look forward to?
I'm not a DYI guy, so I'm trying to see what I am looking at going forward.
Thanx
Phil in Bellflower
Phil in Irvine
WBCCI # 9759
2002 34 Slide Out Lounge
2005 Yukon XL, 3/4 ton, 4WD, 8.1 engine
pjtaia is offline   Reply With Quote
Old 08-20-2013, 09:12 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy,,, generally a yearly task that is best to be maintained or task more difficult.
It is a good time to reseal immediately , too.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-21-2013, 11:23 AM   #3
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
The super-shiney, mirror-like vintage trailers you see are usually touched up once a year and do not have clearcoat on them. It depends on where you live / travel / store your trailer as to how often you will have to touch it up to maintain that look. In higher humity areas or around saltwater it will oxidize faster than in drier climates.
The annual maintenance, if done yourself (we do), will take about two weekends or 40 +/- hours. Expect to pay about $50 per lineal foot (22' trailer = $1100) for a touch-up/repolish of a recently polished trailer if you don't want to DIY. If it's either too oxidized or a first time polish, it will generally run $100-150+ per lineal foot or take upwards of 150-200+ hours to DIY.
Some folks choose to polish it once and either clearcoat it or just let it re-oxidize for an overall less shiney finish and less maintenace. New clearcoat finishes only last 5-7+/- years then will they have to be stripped and re-done unless you are able to store your trailer indoors. If you do have clearcoat or choose to go that route, the Walbernize line of products help maintain it longer, as wax does for a car's clearcoat.
Shari
Old 08-21-2013, 06:37 PM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
20 months on last polish
It certainly could have used a polish after 12 months, but looked OK from 20'.
I had to start with F7 on the polisher, but one day on the cyclo with C and one day with S it looks pretty good. Look up the "Nuvite" polish system. Three days to bring the shine up.
The more often it is polished the easier it is to put a top polish on.
Mine lives under an open cover, but seldom gets wet.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-21-2013, 08:57 PM   #5
1988 32' Excella
Robbinsville , New Jersey
A 1996 will look cloudy when it is first polished. It is a different type of aluminum then the older trailers and wont get a mirror finish.
Not sure how that effects maintenance though.
Wazbro is offline   Reply With Quote
Old 08-21-2013, 09:49 PM   #6
Irvine , California
Images: 11
Thanks for the input. I don't need a mirror-chrome finish, but the cloudy look is a little annoying. I'm in coastal SoCal, but I don't have an indoor storage place. I will be looking to have a re-polish done, then consider a clearcoat. Sounds like a plan...
Phil in Irvine
WBCCI # 9759
Old 08-22-2013, 10:52 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you can try Toolbox polish from Lowe's on a rotary polisher it might do what you want. It has worked well for many others.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-23-2013, 08:12 PM   #8
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Check out this thread, it has a lot of detailed photos and comments. I believe it is also about the same year, and therefore probably the same aluminum finish that you have. I could be wrong about the similarity in the years, it has been a while since I read this thread.
1996 Excella Strip and Polish - the slow way
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
