Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum
Old 04-03-2014, 11:26 AM   #1
1989 29' Excella
2018 30' Classic
Cumming , Georgia
Images: 12
LED Bullseye Clearance replacement Lights
HI,
I'm considering replaceing my facorty clearance lights with new LED Bullseye type where they're sealed.
You tube is failing me on this one.
Couple of questions, ...
1. Is the uninstall of the existing lights pretty straight forward?
2. Is the install pretty simple? I keep seeing sentances that say, 'Must relocate wiring????
Dave
davcarv is offline   Reply With Quote
Old 04-09-2014, 10:22 PM   #2
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Can you supply photo of the bullseye lights?
Howard L. is offline   Reply With Quote
Old 04-10-2014, 05:22 AM   #3
SteveH's Avatar
Common Sense , Texas
Originally Posted by davcarv View Post
HI,
Dave
Just my opinion here, but I've had them on a previous trailer, and while they look cool, they're a PITA to work on, and the regular bulb type are easy to work on. And things happen, like a bear broke one of ours. They are also expensive.
Regards,
Steve
Old 04-10-2014, 06:31 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
If you can master a screwdriver, you can switch the lights. First of all....watch the wiring. It is always to short and you can loose the working end inside the wall. Thats a problem..
Go with newer LED fixtures. They come in the same Bullseye lens. You can always just change the bulbs to LED...a simple plug in swap.
EBAY, AMAZON, most anywhere.
Don't forget to seal them well.....everywhere. Those lights are the source of many water leak problems.
A good deal LED clearance lights! Anon Lights - Interior & Exterior 13 10-17-2013 10:39 PM
Replace double bullseye markers with teardrop. Sacrilege? Jamiep Lights - Interior & Exterior 3 09-17-2011 10:20 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 09:54 PM
