Old 04-12-2012, 06:49 AM   #1
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
Keys ?
1.My 1975 overland did not come with any keys... what can I do? I have done a search on the forum and found that apparently they all use the same keys? but is it possible to buy them or do I need to go to a lock smith? replace all the locks $$$$? I am confused and new so be gentle..
dkrukosky is offline   Reply With Quote
Old 04-12-2012, 07:16 AM   #2
Basically, the keys are not available.
However, a new tumbler comes with 2 keys.
The tumbler takes about 10 seconds to replace.
Old 04-12-2012, 07:42 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I pulled my Caravel to the local Locksmith and he made new keys (and spares!!) for all the locks right then and there.
It was about a 20 dollar job. He probably did what Andy said here.
Old 04-12-2012, 09:41 AM   #4
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
do the pop locks on compartments and main door use the same tumbler?
Old 04-12-2012, 10:21 AM   #5
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Same here. Locksmith made all the keys in about 15 minutes. No big deal.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 04-12-2012, 10:28 AM   #6
No, they are totally different.
Old 04-12-2012, 12:48 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Bambi II takes 6 different keys get into everything. 4 for compartments and 2 for the door. Plus 4 different keys for the hitch set up. Total pain. Low priorty but I am going to change them all out to match (as much as possible) one of these days.
MICHAEL
Old 04-12-2012, 02:46 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
I believe that the compartment doors are standard, and are available from Airstream and other sources. There used to be a chart on the airstream web site but it's gone now. You should be able to get the compartment door keys here:
Keys : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
For the door keys you can, as others have posted, either replace the lock or have a locksmith make keys.
Old 04-13-2012, 10:31 AM   #9
No need to replace the lock.
Tumbler replacements are available for the KT lock that was used from 1970 to 1977.
Old 04-16-2012, 05:58 AM   #10
dkrukosky's Avatar
1975 27' Overlander
Elkton , Maryland
ok so new cylinder for the door and replacement key for the hatches. Now just a full restoration and a tow vehicle and I am ready to go...
Old 04-16-2012, 06:15 AM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
You're practically done!
