Old 11-12-2015, 02:06 PM   #1
1969 23' Safari
Athens , Georgia
Is this the Filiform of which I've heard spoken?
I've about stripped all the clear coat and decided to see how the Nuvite products worked. I got F9, C and S.
I did about 30 passes of F9 because I couldn't get it smooth. Then I tried some of the C and this is what I have. Did about 4 passes on an 18" or so section. What's the final word on getting this corrosion compounded out? I'm terrified to use sand paper. Is that my only option?
sarasafari is offline   Reply With Quote
Old 11-12-2015, 02:35 PM   #2
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Picture?
Dingo Girl is offline   Reply With Quote
Old 11-12-2015, 03:13 PM   #3
1969 23' Safari
Athens , Georgia
Sorry, pic didn't download
Hope it attaches
Old 11-12-2015, 03:21 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Try some mineral spirits on a rag and see what happens
Old 11-12-2015, 03:22 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Looks like filiform, however....
If you have done that many passes with F9 something is wrong with your polishing. Have you stripped the clear coat off? Are you compounding with a wheel? F9 with just a pad or a Cyclo will not cut thru the clear coat and polish.
Tell us what your doing.....your trailer will sparkle if done right.
Old 11-12-2015, 04:09 PM   #6
1969 23' Safari
Athens , Georgia
Clear coat is definitely off of this part. It's the rear end cap and came off in a sheet with citrus strip.mI'm compounding with a random orbiter with wool bonnets. I went through 2 bonnets with this one spot, spurring them in between, along with in between buffing and wiping down with mineral spirits. So, 5 black rags, 2 bonnets, 2 hours later, this is what I have. Normal?
Old 11-12-2015, 04:11 PM   #7
1969 23' Safari
Athens , Georgia
My worry is, that my whole trailer has these scars.
Old 11-12-2015, 04:44 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
What kind of random orbiter do you have? You may need to go with a variable speed angle grinder.
I am not a Nuvite expert, it not the only way to skin the cat. I use bar tripoli and rouge and sometimes whatever else is at hand including Mother's Truck Box Polish.
Your photo is not the greatest. A macro photo would help. But it does not look like filiform which is little white wormy squiggly stuff that would have been there from the get go.
Old 11-13-2015, 07:03 AM   #9
1969 23' Safari
Athens , Georgia
It's a porter cable 6" variable speed random orbit sander/ polisher. I decided not to go with the heavier/bigger 7" one because I have arthritis in my elbow. Theses are definitely "scratches" that you can feel with your fingers.
Old 11-13-2015, 07:41 AM   #10
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Like I said...THAT type polisher is NOT going to get it done.
Old 11-13-2015, 07:45 AM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
I'm afraid I agree. But, even with better equipment polishing takes a lot of work. That's why the pros get thousands of dollars.
Old 11-13-2015, 10:34 AM   #12
jackson center , Ohio
The metal is pitted due to time and exposure....corroded.not necessarily filiform though.Which is normally white powder (looks worm like)under the coating.
You will only be able to polish the aluminum so deep and some will not come out.
Schu is offline   Reply With Quote
Old 11-13-2015, 10:44 AM   #13
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
It seems that, like cars, boats, airplanes, and yes, even myself - something that is getting old simply cannot be made 100% new again. Wear those battle scars with pride!
kdickinson is offline   Reply With Quote
Old 11-13-2015, 11:45 AM   #14
2013 Interstate Coach
La Center , Washington
I was looking to polish a set of wheels last year that looked similar in nature, and found some great information on the web. I presume you have looked at other sites as well, but figured I will post some links to a few that might provide some additional insight. A couple of favorites;
Polishing - Vintage Airstream
Metal Polishing Equipment : Auto Detailing Supplies : Electric Car Polishers : Airplane Polish : Auto Polisher : Aluminum : Polishers and Buffers : PerfectPolish.com
Here is one that goes over the polishing method on some tough looking material
Using the Compounding Polisher : Aluminum Polish : PerfectPolish.com
some info on aluminum corrosion
Corrosion Control For Aircraft
Airstream trailers - Strip and Polish
Scroll down the page about half way to see an article on polishing and AS
Interesting Before & After polishing pictures from Customers and clients
Hope it helps,
Drew
Retired Air Force
Drewsome is offline   Reply With Quote
removing filiform searcher Ribs, Skins & Rivets 5 06-27-2010 10:26 AM
Filiform - only newer trailers or older too? Soyboy Ribs, Skins & Rivets 11 10-05-2008 10:36 AM
Nuclear Reactor Corrosion versus Airstream Filiform Ray Eklund Ribs, Skins & Rivets 0 06-08-2008 12:56 PM
Filiform Corrosion? Harper Ribs, Skins & Rivets 7 06-08-2008 10:45 AM
Filiform corrosion Brad Hunt Ribs, Skins & Rivets 4 11-19-2007 12:17 PM
