Old 01-14-2013, 08:12 PM   #15
matthorr's Avatar
2012 25' FB International
Annapolis , Maryland
Now this will really blow your mind...
You can have corrosion even when composite (non-metallic) materials come in contact with metals. All you need is an electron source, an electron receptor and a path for the current (an electrolyte). The farther apart two metals are on the chart above, the more stronger tendency to "swap" electrons. Corrosion is basically a chemical reaction similar to a battery, so preventing the flow of electrons (current) using a coating, a gasket and/or keeping the materials dry and clean is the key. And treat corrosion promptly (by removing it and re-applying oil/coating/sealant).
matthorr is offline   Reply With Quote
The quest for a new stainless steel frame boatdoc Repairing/Replacing Floor &/or Frame 64 11-28-2015 07:43 PM
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
Liquid Stainless Steel? Hank A General Interior Topics 49 07-29-2012 10:29 AM
Stainless Steel Cleaning help surferstyler Interior Restoration Forum 10 08-23-2006 05:44 PM
stainless steel wheel simulators Larry Brown General Motorhome Topics 11 11-26-2002 08:10 PM
