Old 11-26-2006, 05:18 PM   #1
Cos
1973 21' Globetrotter
Middletown , Rhode Island
Is a plunger going to help this?
Is a plunger going to help this dent (in an AS I'm considering buying)? Can I get behind this from the inside to push it out some?
Cos is offline   Reply With Quote
Old 11-26-2006, 05:28 PM   #2
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
nope. it's creased and while you may be able to push it out some it's in need of replacement if you want it to look new. It also appears that the horizintal rib (the rivet line) is pushed in a little.
I don't think those lower panels are the formed (expensive + hard to get) type so replacing it may not be too big of a deal. I'm sure a few of our master skin replacement experts will chime in with better and more hands on experience shortly.
Perhaps it's simple a beauty mark and some negotiating power with the sale.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-26-2006, 05:48 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I'm no expert but I appreciate brilliance
Originally Posted by swebster
... I'm sure a few of our master skin replacement experts will chime in with better and more hands on experience shortly...
Janet had a great idea in post 10 of this thread.
Tom
Old 11-26-2006, 07:27 PM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
looks pretty permanent to me. Does it leak-- let moisture inside? Does it kill you to look at it? put some stickers on it and use the plunger up the side of the head of the sinner.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-27-2006, 06:57 AM   #5
Cos
No it doesn't leak but it does bother me - I don't need it 100% but I need to know I can make it look better. This is a 73 GT I'm close to buying. How would I get to the inside of this? Would I need to damage something inside to get to it?
The trailer otherwise seems pretty solid, stored carefully and checked on. I would the guy to take $500 or 600$ off his 3K asking price because of the dent but he isn't moving.
Old 11-27-2006, 07:06 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You might be able to cover it with a set of segment protectors....
Richard
Old 11-27-2006, 07:19 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you don't need 100% you migth try removing the interior skin and with someone on the outside working it out. The material is streched and it will not come out flat but you should be able to get most of it back.
You might look around for an old auto body man who knows how to remove dents, not a body filler guy, and see if he will give it a shot. Keep in mind he can't get 100% with alum.
2004 Excursion 4x4
Old 11-27-2006, 10:06 AM   #8
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
I would not move from 3K either, someone else will buy it for that.
www.popasmoke.com
YETI ( 65 Quart )
Old 11-27-2006, 10:57 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
inside
I have a 71 globetrotter and this is what it looks like from the inside. You will notice that I have to replace the same panel
Old 11-27-2006, 05:58 PM   #10
All quarter panels from 1969 on up are stretch formed.
All quarter panels from 1968 and older are made from flat material.
You can oly replace like with like.
Break Away Switch and Lanyard Question RBolton Brakes & Brake Controllers 6 01-10-2007 02:10 PM
Hello Everyone Macozil Member Introductions 11 03-20-2006 08:54 PM
Steps Opening And Closing For No Reason wb13798 Mechanics Corner - Engines, Transmission & More... 22 07-15-2005 06:06 PM
eBay (again) Cedars Our Community 29 01-31-2004 06:28 AM
