Old 05-28-2015, 09:53 AM   #1
1968 24' Tradewind
Carlsbad , California
How much tension on frame/shell?
I have lowered the shell back onto my frame after replacing the flooring and floor channel. My issue is that when I set the shell in place I have about an inch gap at the rear-left corner. I can lift up on the bumper and close the gap.
My questions are, is this normal? How much "flex" is there in the shell? Should I lift the shell back off and have the frame "straightened" at a body shop?
My concern is that the shell may buckle, or rivets may shear under load. Any input is greatly appreciated.
shilgemann is offline   Reply With Quote
Old 05-28-2015, 08:12 PM   #2
Mixter's Avatar
1976 27' Overlander
Normal. Contrary to the common misconception that the frame holds up the shell.... The Shell actually holds up the frame. you may have to jack up several areas of the frame to get it back to level all the way around. There will be lots of flex.
Good luck!
Mixter is offline   Reply With Quote
Day/night shade tension adjustments? cwf General Interior Topics 3 03-15-2013 08:39 AM
Sufficient Sway Bar Tension? Frank&Mike Hitches, Couplers & Balls 7 10-29-2012 04:37 AM
How much frame rust is too much? Toasty's Dad Repairing/Replacing Floor &/or Frame 38 06-24-2012 08:55 AM
Tension on Zip Dee? bwaysteve Awnings 3 06-19-2010 12:57 PM
Throttle tension & Cruise control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 10 07-14-2005 09:01 PM
