Old 07-01-2016, 02:48 PM   #1
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How I removed a dent in the front end cap
My Argosy 26 has had a beach ball size dent in the front end cap ever since I bought it.
I was successful in removing the dent using an inner tube, a piece of plywood and a home made fitting for the shop vac hose.
I placed the inner tube centered over the dent, then placed the plywood on the inner tube. Connected the shop vac hose to the fitting and turned on the vac.
The inner tube had about 5 pound of air, making it flexible and able to make a good seal with the plywood and coach skin.
NOTE: There were no creases in the dent.
I am not sure what the atmospheric pressure is at 4,200ft elevation. I know it is less than at sea level. I am guessing it is about 12.5 pounds per square inch. It's not the vacuum that restores the metal to it's original shape, it is the pressure from behind.
Isn't physics GREAT!
Sorry! the pics are not in order. Look at the last 2 first. Those are the before.
http://s1166.photobucket.com/user/do...Dent%20Removal
Old 07-01-2016, 04:09 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Great Idea!
I think you can buy a gadget that is somewhat similar from princess Auto - it uses a large rubber suction cup and uses a compressed air hose and venturi device to draw a vacuum inside the cup.
I had a dent on top of the front cap of our trailer when we bought it used. I didn't know about it when we bought the trailer as it wasn't visible from the ground, so no big deal really.
I would expect it was caused by someone being up top and kneeling on the end cap - not a good thing to do.
I could have just left it as it was not readily visible but decided to have a try just to see if I could. It pulled out quite easily with a large suction cup (6-8" diam?) used for auto dent pulling - it worked fine but did leave the very slightest trace of a crease around the edges of the dent.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-01-2016, 04:23 PM   #3
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Wow!
I always thought I was a pretty good Hillbilly Engineer, but I am humbled by your innovation.
NICE WORK!
ALUMINUMINUM is offline   Reply With Quote
Old 07-02-2016, 09:50 PM   #4
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
I had a sizable dent in my front 13-panel endcap (on a 1956 Flying Cloud). After removing the interior skins, I used a partially deflated basketball (pushing from the inside) with good results. See here.
Hank
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Old 07-03-2016, 08:11 AM   #5
1981 31' Excella II
New Market , Alabama
Very clever idea there. Good job.
Perry
Old 07-03-2016, 10:18 AM   #6
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Great idea TGT! I'll keep that one in my tool kit
DryFly is offline   Reply With Quote
Old 07-03-2016, 11:12 AM   #7
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
A fantastic solution with outstanding result.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 07-03-2016, 02:24 PM   #8
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
OK TG can you explain it again. I looked at the pictures and it came out great and we have a very similar dent. But I'm just not understanding your sequence.
Inner tube first, then wood, then blow up the inner tube, are you inside or outside.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-03-2016, 02:54 PM   #9
2011 30' Flying Cloud
Greenback , Tennessee
I love it! It sounds like something my dad would have devised. Simple, cheap and effective.
Gneiss Guy is offline   Reply With Quote
Old 07-03-2016, 03:07 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Working from the outside.
Put 5'#'s or so of air in the inner tube. The tube in the pic is for a 15" tire. It is inflated enough to make it round and spongy.
Place the tube so that it encircles the dent.
Lay the plywood on the tube.
Connect the vacuum cleaner hose to the fitting in the plywood.
Press down on the plywood enough to get the tube to squash some.
Turn on the vac.
Picture the tube as the white filling of an Oreo cookie. The coach skin being one side of the cookie and the plywood the other side of the cookie.
I used a 16 gallon Craftsman vac with a clean filter. It has significant suction capabilities.
To test the setup. I laid the tube on the concrete floor of my shop (not smooth by any means). Laid the plywood flat on top of the tube. Connected the vac hose and turned it on.
The plywood sucked down, squashing the tube some. With the vac running I tried lifting the plywood off. It would not budge.
Thought to myself. "This might just work" and it did.
Hope this helps.
Old 07-03-2016, 04:24 PM   #11
1961 28' Ambassador
Mesa , Arizona
Thx for the further information. So the suction is enough to lift out or suck up the dent. Thx
Hittenstiehl
Old 07-03-2016, 05:02 PM   #12
Grosspoluter's Avatar
Franklin Park , Illinois
Wow
WOW
Very cool
It's posts like yours that I love to see!
Wish pictures loaded on this forum easier
I'm going to try this, when I get some spare time
Thanks again!
Grosspoluter is offline   Reply With Quote
Old 07-03-2016, 05:46 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Under normal circumstance the atmospheric pressure is equal on both sides of the outer skin.
When you create a negative pressure on the outside of the skin with the tube, plywood and shop vac.
The atmospheric pressure is reduced, but the pressure on the inside of the skin is still the same. It is that ~ 14 pounds per square inch that actually causes the dent to push or pop out.
The higher in altitude you are the lower the atmospheric pressure. Therefor less push.
I live at 4,200ft in elevation. This method worked fine.
Old 07-04-2016, 07:03 AM   #14
Penokee , Kansas
Too simple... and it worked...
I asked the same question..I felt he stuffed the inner tube into the roof area from the inside... When my friend TG wrote back I had to slap myself in the head as its so simple.. I have a dent on the rear cap of our Overlander I am going to rig up and try this same trick..
Thanks my friend TG for such a simple fix..
Sodbust
Sodbust1 is offline   Reply With Quote
Can this dent be removed with suction? groovzilla 1974 - 1979 Sovereign 11 11-28-2013 11:41 PM
Can This Dent Be Removed? KJRitchie Ribs, Skins & Rivets 22 06-09-2013 06:20 AM
Front end cap 73 Safari SafariGeorge Upholstery, Blinds, Walls & Interior Finishes 2 08-19-2010 07:24 AM
Front ABS end cap repair Meeker Upholstery, Blinds, Walls & Interior Finishes 10 03-26-2010 12:42 PM
front, end cap George Ribs, Skins & Rivets 9 04-07-2003 04:48 PM
