Old 07-18-2016, 12:30 PM   #15
nevans's Avatar
1985 34' Excella
Victoria Harbour , Ontario
another dent pulling story
That is a wonderful solution posted by TG Twinkle.
I pulled a dent in the rear end cap this weekend, but I purchased a dent puller much like Wingeezer described after seeing a post on pinterest about a similar successful project. I was able to pull the dent, but of course the gouges made by branches, etc are still there.
I also attempted to pull a dent from the left rear corner. The line of the curve now follows its original arc, but I have several creases that could not be removed due to the nature of the original damage, and the compound curve of the corner panel.
Neil
ID:	267151   Click image for larger version
nevans is offline   Reply With Quote
Old 04-28-2017, 09:19 AM   #16
2012 25' FB International
Evanston , Illinois
What is the black fitting that lines the hole in the plywood? If you made it, what is the material?
Hi-Ho Silver!!
JerryMcMunn is offline   Reply With Quote
Old 04-28-2017, 09:25 AM   #17
Mollysdad's Avatar
Genius!
I'm thinking a small inner tube for a garden tractor or small trailer (10") would be perfect.
I know there are dent specialists who do this for a living.
Seal, vacuum, pop. It's not perfect because some dents are stressed, but the cave in will come out.
Old 04-28-2017, 01:12 PM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It is actually the lid of a plastic bottle. I cut a hole in it that fit tightly on the vac hose. All that is necessary is to get a good seal between the plywood and the vac hose.
TG Twinkie is online now   Reply With Quote
Old 04-28-2017, 02:15 PM   #19
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I didn't see this thread the first time around. Now that the thread was resurrected today it came up on my RADAR screen.
Definitely an interesting solution. I'll certainly try to remember this situation for future reference. I like the idea of using the negative and positive pressure to pop out the dent. I have a few dents (much smaller than yours) and some of them have creases. Regardless, I think I might try this type of "fix" to see what happens.
The end cap for your Argosy is made of steel and for that reason I don't think there are any (or not many) ribs under the end caps.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 05-07-2017, 04:51 AM   #20
Brad H's Avatar
1974 Argosy 24
Munising , Michigan
Thank you!
I have to thank TGT for the idea! I tried this out yesterday and couldn't believe how easy it worked. I happened to be cleaning the trailer and came across a basket of beach stuff that had a cheap swimming tube from Family Dollar in it so I thought, what the hell, might as well try it. So I filled it until it was almost full but still flexible. Then I seen the old piece of countertop that I cut out for my kitchen sink in the house, perfect! It's nice and heavy so it gave me a good seal.
I looked around to see what I could make a hose fitting out of with no luck. Ended up taking a spade bit and drilling a 5/8" hole in the center of it and figured I would use my hand to seal around it while holding the shop vac hose. Little did I know that the hose sealed itself just fine on the flat surface with the suction. I think it took all of .0001 seconds from putting the hose over the hole until I heard the "thump" of the dent popping up. Very cool!
I apologize for the sideway pics, they weren't that way when I uploaded them.
ID:	284939   Click image for larger version
ID:	284941   Click image for larger version
Brad H is offline   Reply With Quote
Old 05-07-2017, 07:01 AM   #21
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
...snip...
I remember seeing it and not getting exactly what the OP was saying - this piped back up again with recent discussions and I reread the thread - I get it now - very ingenious!!!
I have a question though - you mention the end caps on the argosy being steel - would this process work for aluminum? I thought it was much less forgiving than steel when dented?
Thanks! Love (and wish I shared) the ingenuity of the folks on the forums!!
SteveSueMac is online now   Reply With Quote
Old 05-07-2017, 10:00 AM   #22
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Brad H
Thanks for posting the pics. As they say it's worth a thousand words. My original written explanation was not clear to some.
I see no reason this would not work on aluminum.
Old 05-28-2017, 10:43 AM   #23
Evanston , Illinois
I used this method and it worked great! The dent in the end cap was caused by a basketball hitting it straight on. There was no creasing. There is no sign of the dent now. Thanks, TG Twinkie!
Hi-Ho Silver!!
Old 06-27-2017, 05:05 PM   #24
beaumont , Texas
dent
wow.. thanks Twinkie.. what a great idea. I would like to have been with you not only to see it, but when you were devising the plan.
Dixie722 is offline   Reply With Quote
Old 11-09-2017, 11:56 AM   #25
Colorado Springs , Colorado
Great idea, I think my new old '76 Argosy is leaking (in part) as a result of a dent in the front, I can't wait to give this a try!
Argosynaut is offline   Reply With Quote
Can this dent be removed with suction? groovzilla 1974 - 1979 Sovereign 11 11-28-2013 11:41 PM
Can This Dent Be Removed? KJRitchie Ribs, Skins & Rivets 22 06-09-2013 06:20 AM
Front end cap 73 Safari SafariGeorge Upholstery, Blinds, Walls & Interior Finishes 2 08-19-2010 07:24 AM
Front ABS end cap repair Meeker Upholstery, Blinds, Walls & Interior Finishes 10 03-26-2010 12:42 PM
front, end cap George Ribs, Skins & Rivets 9 04-07-2003 04:48 PM
