Old 08-17-2008, 06:38 PM   #1
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
How do I remove this @#$% tape?
We are preparing to begin the process of polishing our 63 Ambassador. Unfortunately, each winter the previous owner taped a tarp completely around the exterior to keep out the wind and did not remove the tape. So, now we have a beautiful Airstream with a line of tape around the middle. The tape is so old and cracked it will not budge. I have tried Oops, Goop, graffiti remover, Lacquer thinner, paint thinner, heat gun, lighter fluid, nothing works. If anyone has any suggestions please let me know. Someone mentioned Acetone but I'm afraid to use it. Please help!!!
63silver
63Silver is offline   Reply With Quote
Old 08-17-2008, 06:40 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
3M Pinstripe Removal Wheel ZZ3000
Your Price Qty
$34.95
Detailed Description The 3M Stripe Off Wheel is designed to work with common drills for highly efficient removal of thermoplastic adhesives and films such as automotive stripes, decals and molding. Stripe Off Wheel removals may be made without damage to paint, glass and many metal substrates.
Old 08-17-2008, 06:50 PM   #3
63Silver's Avatar
1963 28' Ambassador
Images: 43
Thanks overlander63, I'm online ordering one right now. If it works, I owe you an enormous BEER!!! We have worked on this tape for weeks with little to no luck.
63silver
Old 08-17-2008, 06:56 PM   #4
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
Hey 63Silver,
Wow, it sounds like you have tried almost every solvent including it the kitchen sink to remove your problem adheasive residual gunk.
I can think of only two other solvents you might try. Old fashisoned kerosene can work wonders on cleaning up new ploy-adheasives. After that try MEK, methonal eatheal keytone, a great solvent, but use latex golves to protect yourself
KeithC is offline   Reply With Quote
Old 08-17-2008, 07:46 PM   #5
63Silver's Avatar
1963 28' Ambassador
Images: 43
KeithC,
The tape residue will come off with a great deal of scrubbing but we are really having a hard time getting the actual tape removed. The chemicals we have used will not penetrate the plastic coating on the front side of the tape. At this point I'm up for trying anything.
63silver
Old 08-17-2008, 07:48 PM   #6
Well Preserved
1993 21' Sovereign
MEK and acetone are both ingredients of lacquer thinner.
Old 08-17-2008, 07:49 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Try WD 40 - that stuff will soften about any adhesive. Douse a spot, leave it alone for 10 minutes and wipe with paper towels. Work from the edges toward the center.
Paula Ford
Old 08-17-2008, 08:53 PM   #8
2002 19' Bambi
Lafayette , California
Paula Ford
I strongly second the nomination of trying WD-40. Sometimes it is miraculous in what it will remove.
Although it is not necessarily appropriate for this thread, I will mention that WD-40 is a great "polish" for brushed stainless (like rockguards). Spray a little on and wipe around and off. Not my idea, we were told about it by a refrigerator repairman when discussing the brushed stainless finish on kitchen appliances. Just make sure you rub it off to a dry condition (paper towels work great).
Tim A. is offline   Reply With Quote
Old 08-17-2008, 08:58 PM   #9
cameront120's Avatar
1972 25' Tradewind
Some people use olive oil to do the same thing.
North Vancouver, BC
Old 08-17-2008, 09:32 PM   #10
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Sounds as if you've tried most common hydrocarbon solvents. If the more powerful ones mentioned (and perhaps Goof Off - try a painter's supply store) don't work, you might give ordinary water a try, as it will dissolve many things that hydrocarbon solvents won't ... add a few drops of dish detergent to give it lower surface tension.
Next best bet: a smallish nuclear device or photon torpedoes!
AirsDream is offline   Reply With Quote
Old 08-17-2008, 09:33 PM   #11
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
63silver
63silver... Try Goo Gone by Magic American Corp, Clevland, OH. You should be able to pick it up at any hardware store.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 08-18-2008, 06:25 AM   #12
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
Question
Any thoughts on "aircraft" paint strippers??
94Tri is offline   Reply With Quote
Old 08-18-2008, 09:30 PM   #13
63Silver's Avatar
1963 28' Ambassador
Images: 43
I've tried Goo Gone with no luck. i'm going by an auto body shop tomorrow to see if they have the stripping wheel that overlander63 mentioned. I'm also going to try the WD40 just in case.
63silver
Old 08-18-2008, 09:33 PM   #14
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I'd try it and PermaTex gasket remover.
Shari
Anyone have some bedding tape for sale? Geno Windows & Screens 5 10-07-2006 04:19 PM
Duct Tape Popup fireflyinva Off Topic Forum 10 12-05-2004 05:54 AM
Trim tape source(s)? RoyRK Clearcoat, Exterior Paint & Trim 2 06-03-2004 08:29 PM
Eternabond tape sealants Mariner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-08-2004 06:54 PM
Eternabond bonding tape Gwen General Repair Forum 0 08-06-2003 05:00 PM
